MrEvanchi Posted July 13, 2016 Share Posted July 13, 2016 https://docs.google.com/spreadsheets/d/1CLLYz83oIfwXw3RrUv5eBZtyAQM8n0ob3sUkJThHu6w/edit?usp=sharing '07 Legacy GT, Stage 1 AP, 91Oct. (5,500ft. elevation) Ambient temperature approximately 75-80. (Intake 90-105, Plenty'OHeatsoak) Third gear WOT, couldn't make it to redline because of an officer. I haven't been nearing my target boost for quite some time. I'm no good at telling what most of these values should look like in relation to one another. Only my best guess, but doesn't it seem though as if my wastegate is being terribly generous opening that wide down that low? Is the car knocking at all, and freaking out, pulling timing? Forgot to squeeze the variable in there, but "TD Boost Error". What should I be seeing as for that value? From what I can tell, I'm seeing numbers anywhere from +3/+6 during WOT. During normal driving the same day, the AP recorded as much as -14, and as much as +16 in the boost error. Sorry, absolute noob here. Any thoughts? Link to comment Share on other sites More sharing options...
Max Capacity Posted July 13, 2016 Share Posted July 13, 2016 Check out the Tuning Forum and contact http://www.tuningalliance.com 305,600miles 5/2012 ej257 short block, 8/2011 installed VF52 turbo, @20.8psi, 280whp, 300ftlbs. (SOLD). CHECK your oil, these cars use it. Engine Build - Click Here Link to comment Share on other sites More sharing options...
