bradze Posted July 2, 2016 Share Posted July 2, 2016 i have an '11 outback 2.5i. i am going to mount a winch and so i will have to move my HID lights (i like them and do not wanna get rid of them). my question is if i remove the intake silencer how poorly will my engine run? will i get a CEL? here's a pic of my front end currently why not, i like my car Link to comment Share on other sites More sharing options...
zaksween Posted July 2, 2016 Share Posted July 2, 2016 Hey man, so I was bored and took out the air box below the filter and and little silencer thing about 2 weeks ago... I just used the air box and cut plastic to cover the holes and jb welded them back on... So far no cel. No issues... Motor sounds deeper which is what I was going for... Link to comment Share on other sites More sharing options...
bradze Posted July 2, 2016 Author Share Posted July 2, 2016 im not really concerned about sound. you do have a legacy 2.5i, right? Link to comment Share on other sites More sharing options...
zaksween Posted July 3, 2016 Share Posted July 3, 2016 Yeah it's an ej253... Link to comment Share on other sites More sharing options...
GEE-OTTO Posted July 4, 2016 Share Posted July 4, 2016 If it's downstream of the filter go for it just keep it stock from the filter to the throttle body Link to comment Share on other sites More sharing options...
bradze Posted July 4, 2016 Author Share Posted July 4, 2016 i assume you mean under the filter box right? i wanna change my front end and thatll require removing the snorkus and moving the washer fluid reservoir. Link to comment Share on other sites More sharing options...
GEE-OTTO Posted July 5, 2016 Share Posted July 5, 2016 Anything before the filter however you want to route air in is fine the issues start once you move the MAF closer or further away and/or alter the flow from the MAF to the TB. I've seen Baja and OB with land cruiser snorkels mounted and they simply used a elbows to plum it to a modified stock air box. They cut the blub off the bottom and connected to the opening. Link to comment Share on other sites More sharing options...
aperson Posted July 5, 2016 Share Posted July 5, 2016 As long as what you want to remove is pre-filter you'll be fine. However you'll have a decent sized hole in the top of the air box that's pulling in hot engine air. Nothing the ECU can't compensate for but something to think about. I wouldn't be worried about CELs for pre-filter mods. Really only a concern if you're modifying the intake tubing around the MAF sensor. You may get more crap in the filter since it'll be open and it's close to the grill so plan on replacing that more frequently. I have a 3.6r and I removed the milk jug silencer from the bottom of the air box and haven't had any negative effect, since this hole is facing downwards it's not really sucking anything up from inside the fender well, but if you're opening up that area then that's another thing to think about. Perhaps a custom intake box and filter would be best if you want to remove both and not have to worry about filters. Link to comment Share on other sites More sharing options...
bradze Posted July 10, 2016 Author Share Posted July 10, 2016 just gotta figure out something to plug that hole. i frequently go offroad so i definitely cant leave it open. Link to comment Share on other sites More sharing options...
GEE-OTTO Posted July 10, 2016 Share Posted July 10, 2016 Just cut the jug out and couple your snorkus to the jug hole Link to comment Share on other sites More sharing options...
aperson Posted July 11, 2016 Share Posted July 11, 2016 just gotta figure out something to plug that hole. i frequently go offroad so i definitely cant leave it open. Your title says snorkus which I read as the piece behind the grille. The silencer is the milkjug on the bottom of the airbox. Which do you plan on removing? Wouldn't worry if it's just the milkjug. Also how are you mounting a winch? Why not mount the lights to the same mount as the winch? Link to comment Share on other sites More sharing options...
bradze Posted July 13, 2016 Author Share Posted July 13, 2016 i always thought the milkjug was the snorkus. i guess i got it wrong. for the winch im getting a new bumper beam. i will mount lights to that eventually but i will have to get that welded and itll probably be next year for that part. i've already spent a few thousand $ on my stupid car this year. Link to comment Share on other sites More sharing options...
