x__CRASH__x Posted June 29, 2016 Share Posted June 29, 2016 I have a 2005 LGT wagon with stock suspension. I have 2 bent rims, so I'm going to replace them. Will this size fit without any modification? (I really don't understand offset) 17x7 5-100/5-114.3 [+35mm] Thanks Link to comment Share on other sites More sharing options...
housemusic1 Posted June 29, 2016 Share Posted June 29, 2016 Yes. What size tire? Link to comment Share on other sites More sharing options...
x__CRASH__x Posted June 29, 2016 Author Share Posted June 29, 2016 yes. What size tire? 225/45zr17 Link to comment Share on other sites More sharing options...
Max Capacity Posted June 29, 2016 Share Posted June 29, 2016 225/45-17 is what I run on my stock wheels. 305,600miles 5/2012 ej257 short block, 8/2011 installed VF52 turbo, @20.8psi, 280whp, 300ftlbs. (SOLD). CHECK your oil, these cars use it. Engine Build - Click Here Link to comment Share on other sites More sharing options...
x__CRASH__x Posted June 29, 2016 Author Share Posted June 29, 2016 I need to know if the 17x7 5-100/5-114.3 [+35mm] rims I'm looking at will fit without rubbing. I'm worried about the offset. Link to comment Share on other sites More sharing options...
Max Capacity Posted June 29, 2016 Share Posted June 29, 2016 Have you been to the sticky's up top here, http://legacygt.com/forums/forumdisplay.php/wheels-tires-43.html?s=&daysprune=&f=43 305,600miles 5/2012 ej257 short block, 8/2011 installed VF52 turbo, @20.8psi, 280whp, 300ftlbs. (SOLD). CHECK your oil, these cars use it. Engine Build - Click Here Link to comment Share on other sites More sharing options...
