lilbrudder Posted June 22, 2016 Share Posted June 22, 2016 I think my input shaft bearing is going. I haven't been inside the gear box so I was wondering if the bearing is lubricated by the gear oil or is it a sealed bearing? Link to comment Share on other sites More sharing options...
whitetiger Posted June 22, 2016 Share Posted June 22, 2016 5mt is lubed buy splash lube. just gears throwing oil at each other. Link to comment Share on other sites More sharing options...
lilbrudder Posted June 22, 2016 Author Share Posted June 22, 2016 Do you think over filling for a few days would hurt it...like I said it's a dry bearing noise so I'm wondering if done gear oil in there would help. Link to comment Share on other sites More sharing options...
whitetiger Posted June 23, 2016 Share Posted June 23, 2016 if you are right about the noise coming from the bearing, odds are its gone bad. i dont see any harm putting dome more fluid in, but then dont be surprised if it comes out of the vent hose and you have a mess on your hands. Link to comment Share on other sites More sharing options...
lilbrudder Posted June 23, 2016 Author Share Posted June 23, 2016 Oh good point, maybe worth a try Link to comment Share on other sites More sharing options...
Max Capacity Posted June 23, 2016 Share Posted June 23, 2016 Its been talked about over on NASIOC that to over fill a 5mt a little bit is not a bad thing. FWIW, overfilling the engine oil a little is not to bad either in these cars...it will use it soon enough...LOL 305,600miles 5/2012 ej257 short block, 8/2011 installed VF52 turbo, @20.8psi, 280whp, 300ftlbs. (SOLD). CHECK your oil, these cars use it. Engine Build - Click Here Link to comment Share on other sites More sharing options...
