09specb_vt Posted June 21, 2016 Share Posted June 21, 2016 I've done countless hours of searching for a solution on this and I haven't come up with anything. I've got an airbag light for what you would quickly assume is a bad overhead console, but I replaced it and it's still dead. No lights up top. Also my sunroof has no power. Has anyone seen this issue before? I've read through everything close, but I haven't found this yet. Thanks in advance. Link to comment Share on other sites More sharing options...
apexi Posted June 22, 2016 Share Posted June 22, 2016 Just to confirm, you replaced the overhead console controls for the sunroof, map lights, all that, new circuit board and everything? Link to comment Share on other sites More sharing options...
DonnyJagaru Posted June 24, 2016 Share Posted June 24, 2016 Check that the contacts in the plugs haven't been pushed back into the plastic housing. This sometimes happens if they aren't seated properly. I don't recall when I repaired my AirBag light whether these connectors are of that style. Generally they "click" into place on typical Molex and Amphenol plugs'n'sockets. Link to comment Share on other sites More sharing options...
r.lee89 Posted June 25, 2016 Share Posted June 25, 2016 Make sure the Fuse #4 driver side dash is good and ground is good. Link to comment Share on other sites More sharing options...
09specb_vt Posted June 27, 2016 Author Share Posted June 27, 2016 Just to confirm, you replaced the overhead console controls for the sunroof, map lights, all that, new circuit board and everything? Yes I replaced that module. The light bulbs work, but the passenger air bag light and seat belt lights are out. Link to comment Share on other sites More sharing options...
09specb_vt Posted June 27, 2016 Author Share Posted June 27, 2016 Check that the contacts in the plugs haven't been pushed back into the plastic housing. This sometimes happens if they aren't seated properly. I don't recall when I repaired my AirBag light whether these connectors are of that style. Generally they "click" into place on typical Molex and Amphenol plugs'n'sockets. Interesting. I'll look at that more closely. Make sure the Fuse #4 driver side dash is good and ground is good. Will do. Not sure when I'll get to this, but ill keep this thread updated. Thanks! Link to comment Share on other sites More sharing options...
09specb_vt Posted July 26, 2016 Author Share Posted July 26, 2016 Make sure the Fuse #4 driver side dash is good and ground is good. Fuse #4 was it! That fixed all of the issues. Sun roof, seat belt and airbag module, cruise control. I'm not sure why I didn't pull all of those fuses sooner.. Cheers! Thank you. Link to comment Share on other sites More sharing options...
