CovertRussian's 2000 Infiniti G20 - SR20DE+T & 6 Speed
If I'm not updating my Legacy or Outback build threads, it's usually because I'm busy with this car.
This car is mainly my autocross car, but I've bee driving it daily for the last couple weeks and modifying/testing suspension parts :).
What she looked like when I bought her:
http://i160.photobucket.com/albums/t188/covertrussian/Cars/00%20G20t%20KH3/Pics/Purchase/CIMG7539.jpg
http://i160.photobucket.com/albums/t188/covertrussian/Cars/00%20G20t%20KH3/Pics/Purchase/CIMG7540.jpg
What she looks like now:
http://i160.photobucket.com/albums/t188/covertrussian/Cars/00%20G20t%20KH3/Exterior/Wheels/Velox%20Apex/apex_016.jpg~original
http://i160.photobucket.com/albums/t188/covertrussian/Cars/00%20G20t%20KH3/Exterior/Wheels/Velox%20Apex/apex_017.jpg~original
http://i160.photobucket.com/albums/t188/covertrussian/Cars/00%20G20t%20KH3/Pics/Racing/AutoX/2016-0501_Verona01.jpg~original
http://i160.photobucket.com/albums/t188/covertrussian/Cars/00%20G20t%20KH3/Pics/Racing/AutoX/2016-0514_PCA-Verona02.jpg~original
Of course the money shot
http://i160.photobucket.com/albums/t188/covertrussian/Cars/00%20G20t%20KH3/Pics/Engine%20Bay/RRTEngineBay_201506.jpg~original
The tiny mod list...
Engine
SR20DE Roller Rocker
Lowport Intake Manifold
SR20VE Valve Springs (7.5-8k Redline)
STI 520cc Injectors
UR Water Pump Pulley
E60 MAF
Walbro 255lph
Z32 Fuel Filter
Silla Radiator
Turbo
GT28r
T25 Manifold - Ported
T25 J-Pipe - Ported
3" SS Downpipe
Universal Aluminum Piping Kit
Precision 350hp Intercooler
Exhaust
3" VRS Exhaust with 3" STI Muffler
Borla XR-1 40085 Resonator
Engine Management
NismoTronic NEMU & TunerCode
Drivetrain
2003 Spec V 6 Speed Swap
JWT 250mm Flywheel
350z Exedy Stg1 Clutch
Suspension
Fortune Auto 500 Gen 5 - 8k Front / 10k Rear
Cusco P10 Front Strut Bar
Octotat Rear Strut Bar
Addco Maxima Rear Swaybar
Upper Control Arms - Cusco -10mm (-1* Static Camber)
Anti-Lift Kit - Custom 9.5mm
LCA Rewarward Caster Bushing: SuperPro SPF3447K
Rear Beam Arm Bushings - ES 7.3113
Steel Braided HP PowerSteering Line
Outer Tie Rod Ends: L31 Altima
Wheel & Tires
Wheels: Velox Apex 17x7.5
Tires: Cooper RS3-S 225/45/17
Cosmetic
2002 Sport Grille
Front Bumper Mouth
05 LGT 16G 14psi 290whp/30mpg
12 OBP Stock 130whp/27mpg@87 Oct
00 G20t GT28r 10psi 250whp/36mpg
  • Replies 73
  • Created
  • Last Reply
Oh man....I had a '94 G20 that I should not have gotten rid of. That was a great little car. Even bone stock it was pretty fun to drive.
Subbing for a cool build.
Out of the box P10's (91-96), handle so much better then P11's (99-02). Not only where they lighter (100-300lbs depending on the year), they also have IRS.
Nissan was in the middle of going bankrupt when they were building P11's so they went really cheap with rear beams. Nissan did everything in the book to make the beam cars not rotate, like 1/4" to 1/8" rear toe in, very squishy bushings, 12" or so rear roll center that overloads the front tires.
I've been fighting with making this handle good for years, once I bought the LGT, I no longer cared about keeping it as comfortable so now with coilovers and other goodies she's finally coming around.
I actually Autocrossed with Impulse the other month, was only 1-2 seconds behind him! :lol: Though to be fair he had pretty bald tires. Still getting a turbo FWD family sedan to be fast in autocross a challenge :lol:
I remember the struts were going out and I wasn't really loving the ride. I was also broke so I had to go with something lame like Monroe struts. Even with those, the car went back to cornering like it was on rails.
And yes, I looked on Craigslist yesterday. The P10s are CHEAP...
  • 4 weeks later...
I've been so busy with the house haven't been able to update this thread much at all!
I did get to weight the car last week at the scrap metal place, 3,100lbs without me. Guess the suspension/wheels and turbo parts really did add another 150lbs over stock. :lol:
I wish I could say the same about the P11's, they are heavier and the rear beam just makes it handle like crap. I'm getting closer to making it handle like a good racecar should though!
If I didn't have so much vetted in the P11 I would just switch to a P11, heck I'm even considering a rear IRS swap :lol:
  • 1 month later...
I need to get some more build pics posted up, been too busy on the Legacy :).
sweet ride and solid build! You run it in SM?
Thanks! Yup I run in SMF (Thankfully they created FWD class!). I still get my butt owned by slower cars that are way smaller and lighter though. Car with Terminal Understeer + Rear beam + 3k lbs car = hard to be fast on nimble auto-x courses.
  • 6 months later...
I've been bad about giving this thread some love. Lets start with engine prepping for turbo. This motor came with the car, I then swapped in an SR20VE (Nissan's VTEC motor) and turbo charged it.
SR20DE's were originally designed as turbo charged motors thus even the NA models are very turbo friendly, but SR20VE was actually designed as an NA motor, huge intake ports, high overlap cam, lighter valves, crank, higher piston rings, etc. High overlap cams didn't like smaller T2 turbos, or log manifolds even with a T3 turbo. I actually bought and ran OEM turbo SR20VE cams, but I simply got tired of throwing money at that motor to make less then 250whp (FWD can't hook it anyway).
Plus I expected much better MPG's from the variable valve lift motor, instead I got about the same that I got before on the stock block. With all that combined I decided to KISS and just go back to the stock block and turbo it. Remember how I said SR20DE was built as turbo motors originally?
Well the Roller Rocker (RR) was actually redesigned to be more emission friendly in 2000. Sure it was given much more efficient roller rockers, but it was also given a 4 cw crank, lighter valves, higher piston rings (that don't tolerate detonation), and a bunch of other little things, thus this motor is regarded as the least turbo friendly SR20 engine. But Nissan did leave the low overlap (~8*) cams, which makes it small turbo friendly!
Prepping for Turbo
This thing sat for about two years.
http://i160.photobucket.com/albums/t188/covertrussian/Cars/00%20G20t%20KH3/SR20DE%20RR/Swap/CIMG9320.jpg
Stripped it down a good bit
http://i160.photobucket.com/albums/t188/covertrussian/Cars/00%20G20t%20KH3/SR20DE%20RR/Swap/CIMG9322.jpg
Getting ready to engine stand it
http://i160.photobucket.com/albums/t188/covertrussian/Cars/00%20G20t%20KH3/SR20DE%20RR/Swap/CIMG9330.jpg
To properly tap the block for oil return upper oil pan needs to be removed
http://i160.photobucket.com/albums/t188/covertrussian/Cars/00%20G20t%20KH3/SR20DE%20RR/Swap/CIMG9334.jpg
Tapping
Nissan left the mold with a spot for turbo drain even for NA motors.
http://i160.photobucket.com/albums/t188/covertrussian/Cars/00%20G20t%20KH3/SR20DE%20RR/Swap/CIMG9336.jpg
Drilled out and ready to start tapping.
http://i160.photobucket.com/albums/t188/covertrussian/Cars/00%20G20t%20KH3/SR20DE%20RR/Swap/CIMG9343.jpg
First used the medium sized breaker bar, but it was getting to the point where it was hard to keep on tapping.
http://i160.photobucket.com/albums/t188/covertrussian/Cars/00%20G20t%20KH3/SR20DE%20RR/Swap/CIMG9346.jpg
Upgraded:
http://i160.photobucket.com/albums/t188/covertrussian/Cars/00%20G20t%20KH3/SR20DE%20RR/Swap/CIMG9347.jpg
All done
http://i160.photobucket.com/albums/t188/covertrussian/Cars/00%20G20t%20KH3/SR20DE%20RR/Swap/CIMG9349.jpg
Engine Cleaning
As you may have noticed the block is not clean. The valve cover was leaking badly.
http://i160.photobucket.com/albums/t188/covertrussian/Cars/00%20G20t%20KH3/SR20DE%20RR/Swap/CIMG9340.jpg
Bunch of carb/break parts cleaner cans later...
http://i160.photobucket.com/albums/t188/covertrussian/Cars/00%20G20t%20KH3/SR20DE%20RR/Swap/CIMG9355.jpg
Engine
I like the old style oil filter location, thus I try to use it on all of my motors. In this case oil filter housing wouldn't let the intake manifold get in, thus had to cut the bolt shorter
http://i160.photobucket.com/albums/t188/covertrussian/Cars/00%20G20t%20KH3/SR20DE%20RR/Swap/CIMG9367.jpg
RR EGR pipe is too long and restricts flow, thus I pulled it out.
http://i160.photobucket.com/albums/t188/covertrussian/Cars/00%20G20t%20KH3/SR20DE%20RR/Swap/CIMG9373.jpg
http://i160.photobucket.com/albums/t188/covertrussian/Cars/00%20G20t%20KH3/SR20DE%20RR/Swap/CIMG9370.jpg
Getting ready to put in the RR
http://i160.photobucket.com/albums/t188/covertrussian/Cars/00%20G20t%20KH3/SR20DE%20RR/Swap/CIMG9382.jpg
http://i160.photobucket.com/albums/t188/covertrussian/Cars/00%20G20t%20KH3/SR20DE%20RR/Swap/CIMG9384.jpg
Needed a new VC seal, motor looks pretty good for 100k miles.
http://i160.photobucket.com/albums/t188/covertrussian/Cars/00%20G20t%20KH3/SR20DE%20RR/Swap/CIMG9443.jpg
All put together
http://i160.photobucket.com/albums/t188/covertrussian/Cars/00%20G20t%20KH3/SR20DE%20RR/Swap/CIMG9458.jpg
If you noticed the odd hose, well that's my manual IACV since RR manifold doesn't support old styled IACV's.
http://i160.photobucket.com/albums/t188/covertrussian/Cars/00%20G20t%20KH3/SR20DE%20RR/Swap/CIMG9459.jpg
Roller Rocker's IACV lives on the throttle body, while every single other SR20 has it on the manifold. The plan has always been to run a low port manifold on the roller rocker, it only makes sense to run it when you switch to a 16 bit ecu that has a different IACV system.
I think Nissan designed the roller rocker manifold horribly on purpose, they saw what a great motor the RR is and how much more power it makes then regular low ports and they had to detune it. At first I thought Roller Rocker manifold was really designed for low end torque, that's why they suck for power getting, but after doing these tests I'm convinced Nissan just wanted to screw us.
Stock Roller Rocker manifold
http://i160.photobucket.com/albums/t188/covertrussian/Cars/00%20G20t%20KH3/SR20DE%20RR/Lowport%20IM/RRMani01.jpg
It is good for having secondary runners being very smooth, it's actually semi polished, which is impressive compared to any other SR20 manifold's I've seen, which all have horrible casting marks.
http://i160.photobucket.com/albums/t188/covertrussian/Cars/00%20G20t%20KH3/SR20DE%20RR/Lowport%20IM/RRMani02.jpg
Low Port manifold on the other hand has a much bigger plenum that can house a bunch of air.
http://i160.photobucket.com/albums/t188/covertrussian/Cars/00%20G20t%20KH3/SR20DE%20RR/Lowport%20IM/LPMani001.jpg
It also has smoother runners that are slightly longer with less bends. (Do you spy some yellow LGT/STI injectors?)
http://i160.photobucket.com/albums/t188/covertrussian/Cars/00%20G20t%20KH3/SR20DE%20RR/Lowport%20IM/LPMani002.jpg
On the same exact tune I made 10 more wheel horsepower! Also as you may have noticed my power went down, this could be because of stiffer VE valve springs, or because of hot December day, Virtual Dyno does have temperature and pressure corrections which I utilized, thus it's hard to say what could have dragged the power down a bit.
http://i160.photobucket.com/albums/t188/covertrussian/Cars/00%20G20t%20KH3/SR20DE%20RR/Lowport%20IM/RRvsLPManifold.png
The car feels a lot beastlier now, I was actually quite impressed by the felt torque while doing some runs tonight!
Installation Pics
This manifold is a direct bolt on for the most part. There are a few mods that do need to be done in order to run it on the stock RR. First difference is the water temp housing, which I hate for being on the manifold warming up the air!
RR:
http://i160.photobucket.com/albums/t188/covertrussian/Cars/00%20G20t%20KH3/SR20DE%20RR/Lowport%20IM/CIMG9531.jpg
Low Port:
http://i160.photobucket.com/albums/t188/covertrussian/Cars/00%20G20t%20KH3/SR20DE%20RR/Lowport%20IM/CIMG9532.jpg
As expected the water pipes wont line up easily.
http://i160.photobucket.com/albums/t188/covertrussian/Cars/00%20G20t%20KH3/SR20DE%20RR/Lowport%20IM/CIMG9539.jpg
Gotta pull it out and cut it to fit
http://i160.photobucket.com/albums/t188/covertrussian/Cars/00%20G20t%20KH3/SR20DE%20RR/Lowport%20IM/CIMG9543.jpg
Measure once cut twice... Since I did the cut very close to the bend I used a socket to round it out.
http://i160.photobucket.com/albums/t188/covertrussian/Cars/00%20G20t%20KH3/SR20DE%20RR/Lowport%20IM/CIMG9545.jpg
Installed, and now I can use the low port water hose, which for your reference is 1".
http://i160.photobucket.com/albums/t188/covertrussian/Cars/00%20G20t%20KH3/SR20DE%20RR/Lowport%20IM/CIMG9547.jpg
I dislike the aux air regulator, it keeps your cold idle at 1500 rpm for 60-90 seconds. None of my cars have it, and they don't have any issues in the winter. Blocking it with a big bolt that I cut down.
http://i160.photobucket.com/albums/t188/covertrussian/Cars/00%20G20t%20KH3/SR20DE%20RR/Lowport%20IM/CIMG9548.jpg
Water temp sensor and water temp gauge wires need to be extended out to reach the new location
http://i160.photobucket.com/albums/t188/covertrussian/Cars/00%20G20t%20KH3/SR20DE%20RR/Lowport%20IM/CIMG9563.jpg
Got the injectors all wired up
http://i160.photobucket.com/albums/t188/covertrussian/Cars/00%20G20t%20KH3/SR20DE%20RR/Lowport%20IM/CIMG9565.jpg
Installed an EGR block off plate
http://i160.photobucket.com/albums/t188/covertrussian/Cars/00%20G20t%20KH3/SR20DE%20RR/Lowport%20IM/CIMG9570.jpg
Extended the IACV wires from the throttle body to the other end of the plenum
http://i160.photobucket.com/albums/t188/covertrussian/Cars/00%20G20t%20KH3/SR20DE%20RR/Lowport%20IM/CIMG9566.jpg
LP manifold sits too close to the taller RR VC's, thus clearance can be tough. The throttle screw doesn't touch it, but to be safe extended it out with a Thermoblok spacer
http://i160.photobucket.com/albums/t188/covertrussian/Cars/00%20G20t%20KH3/SR20DE%20RR/Lowport%20IM/CIMG9571.jpg
Not much better, but now dust shouldn't cause any issues!
http://i160.photobucket.com/albums/t188/covertrussian/Cars/00%20G20t%20KH3/SR20DE%20RR/Lowport%20IM/CIMG9572.jpg
Low port has shorter throttle cables too, thus mounting them will require some work (had to drill the bracket in new spots). PCV Valve doesn't have much clearance either.
http://i160.photobucket.com/albums/t188/covertrussian/Cars/00%20G20t%20KH3/SR20DE%20RR/Lowport%20IM/CIMG9579.jpg
Fired her up and listened to her purr and smoke
http://i160.photobucket.com/albums/t188/covertrussian/Cars/00%20G20t%20KH3/SR20DE%20RR/Lowport%20IM/CIMG9588.jpg
USDM Roller Rockers come with a very unSR20 redline of a whipping 6700 rpm. I have to shift twice before even getting to 55mph with that redline! :cry:
Luckily a friend chimed in and mentioned that he used to use VE valve springs on his Roller Rocker and that raised the redline to 7800-8000 rpm. This is excellent because JWT is the only one that makes stiffer springs for us, they are very expensive and are out of stock until further notice. You can get a VE valve spring and retainer set for about $50. I personally stole the needed parts from my old VE.
VE Parts Needed:
- VE Dual Valve Springs
- VE Retainers
- VE Inner valve spring seats
Removed the cams and all of that good stuff
http://i160.photobucket.com/albums/t188/covertrussian/Cars/00%20G20t%20KH3/SR20DE%20RR/VE%20Valve%20Springs/CIMG9493.jpg
Notice the Valve shim and rocker guide locations, this is important to remember!
http://i160.photobucket.com/albums/t188/covertrussian/Cars/00%20G20t%20KH3/SR20DE%20RR/VE%20Valve%20Springs/CIMG9495.jpg
Pulle the shims and guides out, make sure to keep them separated, otherwise you will have to reshim the head.
http://i160.photobucket.com/albums/t188/covertrussian/Cars/00%20G20t%20KH3/SR20DE%20RR/VE%20Valve%20Springs/CIMG9499.jpg
Using a valve spring tool I compressed the spring and took out the keepers
http://i160.photobucket.com/albums/t188/covertrussian/Cars/00%20G20t%20KH3/SR20DE%20RR/VE%20Valve%20Springs/CIMG9500.jpg
While I was at it I figured it would be a perfect time to change the valve stem seals. Gotta be very careful when using anything but a proper tool to remove old valve stem seals! If you scratch the valve it will cut the seal and leak. Get a proper tool if you can, I couldn't get one locally and didn't have time to order it.
http://i160.photobucket.com/albums/t188/covertrussian/Cars/00%20G20t%20KH3/SR20DE%20RR/VE%20Valve%20Springs/CIMG9502.jpg
I had a Supertech kit that I bought for the VE, but since I decided to pull the VE before I got around to replacing the seals, I had these handy. Supertech exhaust seals on left oem used ones on right.
http://i160.photobucket.com/albums/t188/covertrussian/Cars/00%20G20t%20KH3/SR20DE%20RR/VE%20Valve%20Springs/CIMG9503.jpg
Installed:
http://i160.photobucket.com/albums/t188/covertrussian/Cars/00%20G20t%20KH3/SR20DE%20RR/VE%20Valve%20Springs/CIMG9504.jpg
VE Valve spring seats:
http://i160.photobucket.com/albums/t188/covertrussian/Cars/00%20G20t%20KH3/SR20DE%20RR/VE%20Valve%20Springs/VEValeSpringSeats.jpg
When you compare it to the roller rocker one, roller rocker bigger valve spring seat has a bigger inner circle. The difference was significant enough for me not to be able to use VE valve seats on RR head.
http://i160.photobucket.com/albums/t188/covertrussian/Cars/00%20G20t%20KH3/SR20DE%20RR/VE%20Valve%20Springs/ValveSpringSeatRRvsVE.jpg
The inner valve seats aren't really meant to be used on the RR, VE has the head machined to fit them, on the RR they wont sit right at first.
http://i160.photobucket.com/albums/t188/covertrussian/Cars/00%20G20t%20KH3/SR20DE%20RR/VE%20Valve%20Springs/CIMG9510.jpg
Once you insert the bigger valve spring it should align the inner seat.
http://i160.photobucket.com/albums/t188/covertrussian/Cars/00%20G20t%20KH3/SR20DE%20RR/VE%20Valve%20Springs/CIMG9512.jpg
Now is the time to put in the inner springs, make sure the painted surface faces down.
http://i160.photobucket.com/albums/t188/covertrussian/Cars/00%20G20t%20KH3/SR20DE%20RR/VE%20Valve%20Springs/CIMG9513.jpg
Installing the retainers with the valve keepers is where I had the most pain. My shoulders are still sour from keeping the valve springs compressed and trying to install the keepers.
http://i160.photobucket.com/albums/t188/covertrussian/Cars/00%20G20t%20KH3/SR20DE%20RR/VE%20Valve%20Springs/CIMG9516.jpg
Something to worry about on the exhaust side, there are oil drain passages. I lost a valve keeper into one of those, hence I started putting a magnet into the hole just in case. Still trying to fish out the valve keeper. Sadly no one locally had a magnetic drain plug for our M12x1.25 drain plugs.
Intake side was a lot more painful then the exhaust side, intake side required me to push up instead of push down. Luckily valve spring tool had a spot where I could add a wrench into for better leverage.
http://i160.photobucket.com/albums/t188/covertrussian/Cars/00%20G20t%20KH3/SR20DE%20RR/VE%20Valve%20Springs/CIMG9519.jpg
All done, finally! This probably was one of the more nerve wracking tasks I've done on the car. What's worse is, I couldn't use the compressor to pressurize the cylinders (it spun the crank). Thus I used TDC per cylinder to stop the valves from falling, that means I had to rotate the crank while the cams where off.
http://i160.photobucket.com/albums/t188/covertrussian/Cars/00%20G20t%20KH3/SR20DE%20RR/VE%20Valve%20Springs/CIMG9522.jpg
You can see the smaller spring hiding in there
http://i160.photobucket.com/albums/t188/covertrussian/Cars/00%20G20t%20KH3/SR20DE%20RR/VE%20Valve%20Springs/CIMG9523.jpg
For those that are curious here are some closeup shots of the roller rocker.
http://i160.photobucket.com/albums/t188/covertrussian/Cars/00%20G20t%20KH3/SR20DE%20RR/VE%20Valve%20Springs/CIMG9525.jpg
I thought I would measure the valve springs to make sure they were still within spec. I'm surprised that the RR ones with 100k miles still are within perfect spec.
http://i160.photobucket.com/albums/t188/covertrussian/Cars/00%20G20t%20KH3/SR20DE%20RR/VE%20Valve%20Springs/RRValveSpring.jpg
VE one is too, granted I measured it at a bigger side, at the smallest side it was at 47.x mm too.
http://i160.photobucket.com/albums/t188/covertrussian/Cars/00%20G20t%20KH3/SR20DE%20RR/VE%20Valve%20Springs/VEValveSpring.jpg
VE Inner spring
http://i160.photobucket.com/albums/t188/covertrussian/Cars/00%20G20t%20KH3/SR20DE%20RR/VE%20Valve%20Springs/VEValveSpringSmall.jpg
So far I've taken her up to 7500 rpm and regular dyno oil and she seems to be kicking fine. I just changed the oil to some 5w30 Valvoline Synthetic, will have some virtual dyno's soon.
VRS Piping kit:
http://i160.photobucket.com/albums/t188/covertrussian/Cars/00%20G20t%20KH3/Engine/Exhaust/Catback/CIMG9193.jpg
The kit works pretty well except for one bend that made the exhaust hang too low and sit on the body of the car.
http://i160.photobucket.com/albums/t188/covertrussian/Cars/00%20G20t%20KH3/Engine/Exhaust/Catback/CIMG0037.jpg
This basically caused the mid pipe to sit too high, and caused the B pipe to sit too low. It also angled it to sit against the car.
http://i160.photobucket.com/albums/t188/covertrussian/Cars/00%20G20t%20KH3/Engine/Exhaust/Catback/CIMG0028.jpg
There was plenty of cutting and welding though, it wasn't quite a straight bolt on, but I also am using a non-standard small ricey muffler that most of these exhausts are meant for.
I love the STI muffler, it is very quiet inside of the car, while sounds beautiful on the outside. Since I went with a 3" turbo-back exhaust, I figured boring out the muffler would have some benefits too.
2.5" OD
http://i160.photobucket.com/albums/t188/covertrussian/Cars/00%20G20t%20KH3/Engine/Exhaust/Catback/CIMG9955.jpg
Used a 3"OD holesaw
http://i160.photobucket.com/albums/t188/covertrussian/Cars/00%20G20t%20KH3/Engine/Exhaust/Catback/CIMG9957.jpg
Here is the input pipe that I had to pull off
http://i160.photobucket.com/albums/t188/covertrussian/Cars/00%20G20t%20KH3/Engine/Exhaust/Catback/CIMG9958.jpg
Had a ton of metal shavings to clean off
http://i160.photobucket.com/albums/t188/covertrussian/Cars/00%20G20t%20KH3/Engine/Exhaust/Catback/CIMG9963.jpg
Drilled out the second tier, that's how far the input pipe went.
http://i160.photobucket.com/albums/t188/covertrussian/Cars/00%20G20t%20KH3/Engine/Exhaust/Catback/CIMG9964.jpg
3" OD to 3" ID pipe fits perfectly
http://i160.photobucket.com/albums/t188/covertrussian/Cars/00%20G20t%20KH3/Engine/Exhaust/Catback/CIMG0020.jpg
I also removed the heatshield so that the muffler could sit about .25" higher
http://i160.photobucket.com/albums/t188/covertrussian/Cars/00%20G20t%20KH3/Engine/Exhaust/Catback/CIMG9967.jpg
http://i160.photobucket.com/albums/t188/covertrussian/Cars/00%20G20t%20KH3/Engine/Exhaust/Catback/CIMG9970.jpg
http://i160.photobucket.com/albums/t188/covertrussian/Cars/00%20G20t%20KH3/Engine/Exhaust/Catback/CIMG9947.jpg
Getting the pipe to the muffler was also fun
http://i160.photobucket.com/albums/t188/covertrussian/Cars/00%20G20t%20KH3/Engine/Exhaust/Catback/CIMG0026.jpg
All of the pipes welded together and painted the welds (since I used regular steel mig wire)
http://i160.photobucket.com/albums/t188/covertrussian/Cars/00%20G20t%20KH3/Engine/Exhaust/Catback/CIMG0038.jpg
Installed:
http://i160.photobucket.com/albums/t188/covertrussian/Cars/00%20G20t%20KH3/Engine/Exhaust/Catback/CIMG0043.jpg
http://i160.photobucket.com/albums/t188/covertrussian/Cars/00%20G20t%20KH3/Engine/Exhaust/Catback/CIMG0044.jpg
http://i160.photobucket.com/albums/t188/covertrussian/Cars/00%20G20t%20KH3/Engine/Exhaust/Catback/CIMG0045.jpg
And finally the most important piece... It's either an air deflector, or an "Oh CRAP my exhaust hanger broke!" bar.
http://i160.photobucket.com/albums/t188/covertrussian/Cars/00%20G20t%20KH3/Engine/Exhaust/Catback/CIMG0042.jpg
Welded it all together
http://i160.photobucket.com/albums/t188/covertrussian/Cars/00%20G20t%20KH3/Engine/Exhaust/Catback/CIMG0023.jpg
http://i160.photobucket.com/albums/t188/covertrussian/Cars/00%20G20t%20KH3/Engine/Exhaust/Catback/CIMG0022.jpg
Finally the idling video
[ame=http://www.youtube.com/watch?v=5YyGGVEOH1k]3in Exhaust STI Muffler - YouTube[/ame]
When I first built the exhaust I was turbo, thus it was pretty quiet and not raspy. After the turbo died and I went NA for a while I had to get a resonator installed. Thus I picked up a 3" Borla from a friend.
http://i160.photobucket.com/albums/t188/covertrussian/Cars/00%20G20t%20KH3/Engine/Exhaust/Catback/CIMG6128.jpg
Heat shields needed a little persuasion with a hammer to make room for the 5" can.
http://i160.photobucket.com/albums/t188/covertrussian/Cars/00%20G20t%20KH3/Engine/Exhaust/Catback/CIMG6127.jpg
About an 1" of space now :)
http://i160.photobucket.com/albums/t188/covertrussian/Cars/00%20G20t%20KH3/Engine/Exhaust/Catback/CIMG6126.jpg
http://i160.photobucket.com/albums/t188/covertrussian/Cars/00%20G20t%20KH3/Engine/Exhaust/Catback/CIMG6137.jpg
http://i160.photobucket.com/albums/t188/covertrussian/Cars/00%20G20t%20KH3/Engine/Exhaust/Catback/CIMG6138.jpg
Now P11's have skid plates in the back, I had to use the hammer on that too.
http://i160.photobucket.com/albums/t188/covertrussian/Cars/00%20G20t%20KH3/Engine/Exhaust/Catback/CIMG6139.jpg
http://i160.photobucket.com/albums/t188/covertrussian/Cars/00%20G20t%20KH3/Engine/Exhaust/Catback/CIMG6143.jpg
Finally the videos..
Here is the no resonator video, I reved to 7k at most here.
[ame=http://www.youtube.com/watch?v=C0MOpNDqAbc]SR20VE 3" Exhaust, STI Muffler, NoResonator - YouTube[/ame]
Second video, reved to 8k twice, bounced off the rev limiter for a little...
[ame=http://www.youtube.com/watch?v=rVGZ60HK7co]SR20VE 3" Exhaust STI Muffler Borla 5" Resonator - YouTube[/ame]
That's it for tonight, I know you came in here expecting a turbo build but so far your you got nothing but NA mods. In next couple posts will be getting into the turbo portion of the build.
Also do keep in mind these are pictures from couple years back and my overall skills (welding included) have gotten much better :lol:.
T25 Manifold
As part of KISS, I used manifold that comes stuck on SR20DET with T25 turbo's, we call them T25 manifolds. The alternative is a GTiR T28 manifold which should have better bends and better flow, thus it sits lower but closer to the block.
Since I'm planning on running a 3" compressor housing, T25 manifold is a better bet for more clearance, even though it's slightly less efficient at flow.
I ported and cleaned up the manifold casting imperfections.
http://i160.photobucket.com/albums/t188/covertrussian/Cars/00%20G20t%20KH3/Turbo/Manifold/T25%20Manifold/CIMG0441.jpg~original
http://i160.photobucket.com/albums/t188/covertrussian/Cars/00%20G20t%20KH3/Turbo/Manifold/T25%20Manifold/CIMG0440.jpg~original
T25 JPipe
JPipe's are the first exhaust components after the turbo, it's basically the first half of the downpipe. Once again we mainly use OEM ones since aftermarket options are very scarce for the FWD crowd (plenty RWD versions though).
Stock T25 J-Pipes have horrible casting marks everywhere, all adds up to bad flow. You can see how much the O2 sensor protrudes and restricts flow too
http://i160.photobucket.com/albums/t188/covertrussian/Cars/00%20G20t%20KH3/Turbo/J-Pipe/CIMG9737.jpg~original
Since I can do closed loop through my wideband with my NismoTronic ecu, I can just block this O2 port and delete the front O2 sensor. Plus it gives you little more space in our cramped engine bays.
http://i160.photobucket.com/albums/t188/covertrussian/Cars/00%20G20t%20KH3/Turbo/J-Pipe/CIMG9740.jpg~original
Here is the bottom up view of where the O2 sensor would be to show how little space there is. O2 sensor block is already installed.
http://i160.photobucket.com/albums/t188/covertrussian/Cars/00%20G20t%20KH3/Turbo/J-Pipe/CIMG7318.jpg~original
After probably 20 minutes of porting
http://i160.photobucket.com/albums/t188/covertrussian/Cars/00%20G20t%20KH3/Turbo/J-Pipe/CIMG7286.jpg~original
http://i160.photobucket.com/albums/t188/covertrussian/Cars/00%20G20t%20KH3/Turbo/J-Pipe/CIMG7289.jpg~original
http://i160.photobucket.com/albums/t188/covertrussian/Cars/00%20G20t%20KH3/Turbo/J-Pipe/CIMG7288.jpg~original
20 more minutes later, this is where I called the quits.
http://i160.photobucket.com/albums/t188/covertrussian/Cars/00%20G20t%20KH3/Turbo/J-Pipe/CIMG7290.jpg~original
http://i160.photobucket.com/albums/t188/covertrussian/Cars/00%20G20t%20KH3/Turbo/J-Pipe/CIMG7291.jpg~original
http://i160.photobucket.com/albums/t188/covertrussian/Cars/00%20G20t%20KH3/Turbo/J-Pipe/CIMG7294.jpg~original
First things first had to make another gasket, I use gasket sheets that they sell at auto stores. They are good for one or two removals, after that need to be remade.
http://i160.photobucket.com/albums/t188/covertrussian/Cars/00%20G20t%20KH3/Turbo/Downpipe/CIMG7308.jpg~original
Downpipe bolted up:
http://i160.photobucket.com/albums/t188/covertrussian/Cars/00%20G20t%20KH3/Turbo/Downpipe/CIMG7323.jpg~original
Had to take a good chunk out of the p11 crossmember to get it to clear the flex pipe.
http://i160.photobucket.com/albums/t188/covertrussian/Cars/00%20G20t%20KH3/Turbo/Downpipe/CIMG7319.jpg~original
Added a wideband bung right behind the flex pipe
http://i160.photobucket.com/albums/t188/covertrussian/Cars/00%20G20t%20KH3/Turbo/Downpipe/CIMG7326.jpg~original
And finally bolted up to the rest of the exhaust
http://i160.photobucket.com/albums/t188/covertrussian/Cars/00%20G20t%20KH3/Turbo/Downpipe/CIMG7321.jpg~original
I Previously had a "Disco Potato" (GT2860rs) before but felt like it was a little too slow spooling for a street/autox car.
http://i160.photobucket.com/albums/t188/covertrussian/Cars/00%20G20t%20KH3/Turbo/Turbos/GT28r/CIMG0279.jpg~original
http://i160.photobucket.com/albums/t188/covertrussian/Cars/00%20G20t%20KH3/Turbo/Turbos/GT28r/CIMG0280.jpg~original
http://i160.photobucket.com/albums/t188/covertrussian/Cars/00%20G20t%20KH3/Turbo/Turbos/GT28r/CIMG0293.jpg~original
Coming from a disco I had to go back to bolted on inlets and outlets.
http://i160.photobucket.com/albums/t188/covertrussian/Cars/00%20G20t%20KH3/Turbo/Turbos/GT28r/CIMG0296.jpg~original
Had to grind the block and turbo as usual to get it to fit
http://i160.photobucket.com/albums/t188/covertrussian/Cars/00%20G20t%20KH3/Turbo/Turbos/GT28r/CIMG0287.jpg~original
http://i160.photobucket.com/albums/t188/covertrussian/Cars/00%20G20t%20KH3/Turbo/Turbos/GT28r/CIMG0288.jpg~original
Used a 2" 90* elbow and all set:
http://i160.photobucket.com/albums/t188/covertrussian/Cars/00%20G20t%20KH3/Turbo/Turbos/GT28r/CIMG0298.jpg~original
http://i160.photobucket.com/albums/t188/covertrussian/Cars/00%20G20t%20KH3/Turbo/Turbos/GT28r/CIMG0299.jpg~original
Went for a test drive and I was boosting over 16psi, for a new turbo the wastegate arm was moving a bit roughly, I dismissed it as a new turbo not broken in issue. Turns out it was a defect, luckily I had yet another GT28r laying around, this one came with a nice coated turbine housing.
While I was at it ported the housing
http://i160.photobucket.com/albums/t188/covertrussian/Cars/00%20G20t%20KH3/Turbo/Turbos/GT28r/CIMG0439.jpg~original
By the time I got around to switching the exhaust housings I was already running OEM fans instead of slim fans. Due to this the GT28r intake housing with adapter wasn't working anymore. I had a spare disco housings laying around and figured I would try using it.
Also got an AGP replaceable spring internal gate, it's huge though, fitment is pretty tight.
http://i160.photobucket.com/albums/t188/covertrussian/Cars/00%20G20t%20KH3/Turbo/Turbos/GT28r/CIMG0451.jpg~original
http://i160.photobucket.com/albums/t188/covertrussian/Cars/00%20G20t%20KH3/Turbo/Turbos/GT28r/CIMG0452.jpg~original
With disco housing look at all of that space
http://i160.photobucket.com/albums/t188/covertrussian/Cars/00%20G20t%20KH3/Turbo/Turbos/GT28r/CIMG0454.jpg~original
Still with oem fans barely any space left
http://i160.photobucket.com/albums/t188/covertrussian/Cars/00%20G20t%20KH3/Turbo/Turbos/GT28r/CIMG0453.jpg~original
All done yet again:
http://i160.photobucket.com/albums/t188/covertrussian/Cars/00%20G20t%20KH3/Turbo/Turbos/GT28r/CIMG0456.jpg~original
Turbo Inlet, 3" takes a lot of room, almost hitting the clutch arm.
http://i160.photobucket.com/albums/t188/covertrussian/Cars/00%20G20t%20KH3/Turbo/Intake/Piping/CIMG0458.jpg~original
Um, you're really good at this stuff... Impressive work and attention to detail.
In for more build porn!
Thanks! I figured those that enjoy my Legacy's fairly mild build thread would appreciate my much more involved car build. Legacy is my daily and I do my best not to over mod it :lol:
I've been through too many intercooler piping setups, here is the latest setup. This routing method allowed me to keep my fog lights.
Hot Side Piping:
2" piping under the radiator support. I got these pipes from my turbo B15 Sentra, they are prewelded and require no thrills to install, which is nice.
http://i160.photobucket.com/albums/t188/covertrussian/Cars/00%20G20t%20KH3/Turbo/Intake/Piping/CIMG9830.jpg~original
http://i160.photobucket.com/albums/t188/covertrussian/Cars/00%20G20t%20KH3/Turbo/Intake/Piping/CIMG9764.jpg~original
Cold Side Piping:
From the intercooler it goes back under the radiator support with 2.5" piping
http://i160.photobucket.com/albums/t188/covertrussian/Cars/00%20G20t%20KH3/Turbo/Intake/Piping/CIMG9765.jpg~original
Gave it plenty of room for radiator fans
http://i160.photobucket.com/albums/t188/covertrussian/Cars/00%20G20t%20KH3/Turbo/Intake/Piping/CIMG9768.jpg~original
All set
http://i160.photobucket.com/albums/t188/covertrussian/Cars/00%20G20t%20KH3/Turbo/Intake/Piping/CIMG9771.jpg~original
Turbo Inlet:
http://i160.photobucket.com/albums/t188/covertrussian/Cars/00%20G20t%20KH3/Turbo/Intake/Piping/CIMG9772.jpg~original
IAT & IACV Ports
In preparation for running MAP with Nemu had to add an IAT sensor to the piping. Plus with the bends that I wanted to take, I didn't have any prewelded pipes. Restored to JBWeld, 4 years later and it's still holding.
http://i160.photobucket.com/albums/t188/covertrussian/Cars/00%20G20t%20KH3/Turbo/Intake/Piping/CIMG9753.jpg~original
http://i160.photobucket.com/albums/t188/covertrussian/Cars/00%20G20t%20KH3/Turbo/Intake/Piping/CIMG9754.jpg~original
http://i160.photobucket.com/albums/t188/covertrussian/Cars/00%20G20t%20KH3/Turbo/Intake/Piping/CIMG9760.jpg~original
IACV Breather and IAT sensors JBWelded in.
http://i160.photobucket.com/albums/t188/covertrussian/Cars/00%20G20t%20KH3/Turbo/Intake/Piping/CIMG9759.jpg~original
The previous intercooler I had was a 2.5" CXRacing one, since I was selling my turbo Sentra and didn't want to sell it with the nicer Precisision intercooler I decided to fit it onto my car. Which required a lot more bumper cutting.
Didn't really want to come to this, but had to take the whole front end off.
http://i160.photobucket.com/albums/t188/covertrussian/Cars/00%20G20t%20KH3/Turbo/Intake/Precision%20350hp/CIMG1695.jpg~original
Drilled a hole in the hood latch support. It was hung like this on the B15 for couple years without any issues, figured it would be good enough (plus it only has one hanger).
http://i160.photobucket.com/albums/t188/covertrussian/Cars/00%20G20t%20KH3/Turbo/Intake/Precision%20350hp/CIMG1696.jpg~original
http://i160.photobucket.com/albums/t188/covertrussian/Cars/00%20G20t%20KH3/Turbo/Intake/Precision%20350hp/CIMG1698.jpg~original
Cut down the lower mount bolt so it wouldn't hit the IC.
http://i160.photobucket.com/albums/t188/covertrussian/Cars/00%20G20t%20KH3/Turbo/Intake/Precision%20350hp/CIMG1697.jpg~original
Next fun, power steering oil cooler. The old intercooler sat closer to the frame, thus couldn't fit the stock PS cooler and had to get an aftermarket one. I couldn't figure out where to put it with this intercooler, since it's 1.5" thicker and has different inlet and outlets.
http://i160.photobucket.com/albums/t188/covertrussian/Cars/00%20G20t%20KH3/Suspension/Steering/PS%20Cooler/CIMG9879.jpg~original
http://i160.photobucket.com/albums/t188/covertrussian/Cars/00%20G20t%20KH3/Suspension/Steering/PS%20Cooler/CIMG1702.jpg~original
Found this from my wrecked auto G20. Brackets didn't quite align so had to resort to good old zip ties in one spot.
http://i160.photobucket.com/albums/t188/covertrussian/Cars/00%20G20t%20KH3/Suspension/Steering/PS%20Cooler/CIMG1704.jpg~original
Intercooler finally mounted
http://i160.photobucket.com/albums/t188/covertrussian/Cars/00%20G20t%20KH3/Turbo/Intake/Precision%20350hp/CIMG1705.jpg~original
Bumper support and sport headlights back on.
http://i160.photobucket.com/albums/t188/covertrussian/Cars/00%20G20t%20KH3/Turbo/Intake/Precision%20350hp/CIMG1708.jpg~original
Trying to get the bumper back on, and as expected it hits the thicker intercooler. Now the shaving fun begins..
http://i160.photobucket.com/albums/t188/covertrussian/Cars/00%20G20t%20KH3/Turbo/Intake/Precision%20350hp/CIMG1710.jpg~original
Here is what the car looks with the bumper uncut, if it magically fit:
http://i160.photobucket.com/albums/t188/covertrussian/Cars/00%20G20t%20KH3/Turbo/Intake/Precision%20350hp/CIMG1714.jpg~original
Let the cutting begin:
http://i160.photobucket.com/albums/t188/covertrussian/Cars/00%20G20t%20KH3/Turbo/Intake/Precision%20350hp/CIMG1715.jpg~original
http://i160.photobucket.com/albums/t188/covertrussian/Cars/00%20G20t%20KH3/Turbo/Intake/Precision%20350hp/CIMG1716.jpg~original
I kind of like the way it looks, reminds me of the TEV bumper
http://i160.photobucket.com/albums/t188/covertrussian/Cars/00%20G20t%20KH3/Turbo/Intake/Precision%20350hp/CIMG1717.jpg~original
http://i160.photobucket.com/albums/t188/covertrussian/Cars/00%20G20t%20KH3/Turbo/Intake/Precision%20350hp/CIMG1718.jpg~original
Sadly it still wouldn't fit had to cut it more. I left it for the night, but it finally mostly fits. I will cut it more evenly later.
http://i160.photobucket.com/albums/t188/covertrussian/Cars/00%20G20t%20KH3/Turbo/Intake/Precision%20350hp/CIMG1719.jpg~original
http://i160.photobucket.com/albums/t188/covertrussian/Cars/00%20G20t%20KH3/Pics/Best%20Shots/SAM_7411_1600.jpg~original
Taking a break from power mods, here are some cosmetic mods.. When the G20 was re-debuted in 1999 Nissan decided to add a lot of chrome. In 2002 they had a Sport trim with blacked out headlights, more aggressive grille and clear side markers.
Sport Blacked out Headlights
Here is what the headlights and grille look like bone stock:
http://i160.photobucket.com/albums/t188/covertrussian/Cars/00%20G20t%20KH3/Pics/Purchase/CIMG7538.jpg~original
Sport headlights are blacked out, but for what ever reason the corners are not!
http://i160.photobucket.com/albums/t188/covertrussian/Cars/00%20G20t%20KH3/Exterior/Lights/Headlights/CIMG9916.jpg~original
Took the corners apart and blacked them out
http://i160.photobucket.com/albums/t188/covertrussian/Cars/00%20G20t%20KH3/Exterior/Lights/Headlights/CIMG9937.jpg~original
http://i160.photobucket.com/albums/t188/covertrussian/Cars/00%20G20t%20KH3/Exterior/Lights/Headlights/CIMG9944.jpg~original
http://i160.photobucket.com/albums/t188/covertrussian/Cars/00%20G20t%20KH3/Exterior/Lights/Headlights/CIMG9941.jpg~original
Sport Grille
I was thinking about modding the stock grille and saving a hundred bucks, but when a black Sport Grille showed up in classifieds it was hard to say no.
Stock Grille
http://i160.photobucket.com/albums/t188/covertrussian/Cars/00%20G20t%20KH3/Exterior/Grille/Sport/Stock%20-%20Front.jpg~original
Sport Grille
http://i160.photobucket.com/albums/t188/covertrussian/Cars/00%20G20t%20KH3/Exterior/Grille/Sport/Sport%20-%20Front%2001.jpg~original
With all these mods the car just looks much more boss
http://i160.photobucket.com/albums/t188/covertrussian/Cars/00%20G20t%20KH3/Exterior/Lights/Headlights/SportHeadlightsandCorners.jpg~original
Sport Side Markers
Stock side markers are very 90's yellow and stick way out
http://i160.photobucket.com/albums/t188/covertrussian/Cars/00%20G20t%20KH3/Exterior/Lights/Side%20Markers/SAM_3108.jpg~original
http://i160.photobucket.com/albums/t188/covertrussian/Cars/00%20G20t%20KH3/Exterior/Lights/Side%20Markers/SAM_3110.jpg~original
Sport side markers are much slicker
http://i160.photobucket.com/albums/t188/covertrussian/Cars/00%20G20t%20KH3/Exterior/Lights/Side%20Markers/SAM_3114.jpg~original
http://i160.photobucket.com/albums/t188/covertrussian/Cars/00%20G20t%20KH3/Exterior/Lights/Side%20Markers/SAM_3111.jpg~original
I always liked the front bumper mouth, it makes the car looks much more aggressive, basically what the GTR or Evo X have.
http://www.thetorquereport.com/nissan_gt_r_group_n_001.jpg
But having a black car meant that painting the mouth flat black would not really be noticeable at all. I decided to try something different and more subtle.
http://i160.photobucket.com/albums/t188/covertrussian/Cars/00%20G20t%20KH3/Exterior/Bumper/Mouth/CIMG9873.jpg
First coat
http://i160.photobucket.com/albums/t188/covertrussian/Cars/00%20G20t%20KH3/Exterior/Bumper/Mouth/CIMG9877.jpg
Let it sit overnight and installed the fogs
http://i160.photobucket.com/albums/t188/covertrussian/Cars/00%20G20t%20KH3/Exterior/Bumper/Mouth/CIMG9882.jpg
On the car:
http://i160.photobucket.com/albums/t188/covertrussian/Cars/00%20G20t%20KH3/Exterior/Bumper/Mouth/CIMG9888.jpg
2015 Update with a bigger intercooler:
This is a summary post of my 6 speed swap, detailed thread can be found over at G20.net.
Summary Pictures Of the Retrofit Swap
350z Clutch (250mm) vs P11 Clutch (215mm)
http://i160.photobucket.com/albums/t188/covertrussian/Cars/00%20G20t%20KH3/Drivetrain/RS6%20Swap/Flywheel/Flywheel_006.jpg~original
JWT S15 Flywheel:
http://i160.photobucket.com/albums/t188/covertrussian/Cars/00%20G20t%20KH3/Drivetrain/RS6%20Swap/Flywheel/Flywheel_007.jpg~original
http://i160.photobucket.com/albums/t188/covertrussian/Cars/00%20G20t%20KH3/Drivetrain/RS6%20Swap/Flywheel/Flywheel_012.jpg~original
Stock trans mount is replaced with the Spec V one
http://i160.photobucket.com/albums/t188/covertrussian/Cars/00%20G20t%20KH3/Drivetrain/RS6%20Swap/Mounts/Trans_Mount_02.jpg~original
http://i160.photobucket.com/albums/t188/covertrussian/Cars/00%20G20t%20KH3/Drivetrain/RS6%20Swap/Mounts/Trans_Mount_30.jpg~original
http://i160.photobucket.com/albums/t188/covertrussian/Cars/00%20G20t%20KH3/Drivetrain/RS6%20Swap/Mounts/Trans_Mount_33.jpg~original
Transmission it self is a good bit bigger and longer, not much room in there now.
http://i160.photobucket.com/albums/t188/covertrussian/Cars/00%20G20t%20KH3/Drivetrain/RS6%20Swap/Install/Install_038.jpg~original
Subframe needs to be cut/shaved in a few locations and rewelded
http://i160.photobucket.com/albums/t188/covertrussian/Cars/00%20G20t%20KH3/Drivetrain/RS6%20Swap/Install/Install_003.jpg~original
http://i160.photobucket.com/albums/t188/covertrussian/Cars/00%20G20t%20KH3/Drivetrain/RS6%20Swap/Install/Install_007.jpg~original
http://i160.photobucket.com/albums/t188/covertrussian/Cars/00%20G20t%20KH3/Drivetrain/RS6%20Swap/Install/Install_010.jpg~original
Clutch slave is in a new location and really close to my turbo inlet.
http://i160.photobucket.com/albums/t188/covertrussian/Cars/00%20G20t%20KH3/Drivetrain/RS6%20Swap/Slave%20Cylinder/P12Slave%20004.jpg~original
Spec V axles do luckily fit, but they are a little short (axle can be seen being stretched). Problem is ABS ring, if you want ABS you need to shave the spec v one a little to fit the P11 over it.
http://i160.photobucket.com/albums/t188/covertrussian/Cars/00%20G20t%20KH3/Drivetrain/RS6%20Swap/Axles/Axles_010.jpg~original
http://i160.photobucket.com/albums/t188/covertrussian/Cars/00%20G20t%20KH3/Drivetrain/RS6%20Swap/Axles/Axles_012.jpg~original
Mazworx Axle bracket is the best way to go, which I brazed so it wouldn't come loose.
http://i160.photobucket.com/albums/t188/covertrussian/Cars/00%20G20t%20KH3/Drivetrain/RS6%20Swap/Axle%20Brackets/Mazworx007.jpg~original
http://i160.photobucket.com/albums/t188/covertrussian/Cars/00%20G20t%20KH3/Drivetrain/RS6%20Swap/Axle%20Brackets/Mazworx010.jpg~original
http://i160.photobucket.com/albums/t188/covertrussian/Cars/00%20G20t%20KH3/Drivetrain/RS6%20Swap/Axle%20Brackets/Mazworx013.jpg~original
Shifter and Cables, here I had to convert to cable driven setup.
http://i160.photobucket.com/albums/t188/covertrussian/Cars/00%20G20t%20KH3/Drivetrain/RS6%20Swap/Shifter/Shifter_042.jpg~original
http://i160.photobucket.com/albums/t188/covertrussian/Cars/00%20G20t%20KH3/Drivetrain/RS6%20Swap/Shifter/Shifter_039.jpg~original
http://i160.photobucket.com/albums/t188/covertrussian/Cars/00%20G20t%20KH3/Drivetrain/RS6%20Swap/Shifter/Shifter_022.jpg~original
http://i160.photobucket.com/albums/t188/covertrussian/Cars/00%20G20t%20KH3/Drivetrain/RS6%20Swap/Shifter/Shifter_024.jpg~original
