lgtlongroof Posted June 14, 2016 Share Posted June 14, 2016 Check engine light came on about 2 weeks ago. code was number 1 cylinder misfire. did plug/coil pack then injector, no luck, did leak down valves good, Piston rings?..need suggestions, love car but currently can't drive for fear of burning up cat. Thanks in advance. JA Link to comment Share on other sites More sharing options...
Max Capacity Posted June 14, 2016 Share Posted June 14, 2016 I'm guessing we're looking for compression test results next ? Normally #2 or #4 are the ones with issues... Has the car always been on the stock MAP ? 305,600miles 5/2012 ej257 short block, 8/2011 installed VF52 turbo, @20.8psi, 280whp, 300ftlbs. (SOLD). CHECK your oil, these cars use it. Engine Build - Click Here Link to comment Share on other sites More sharing options...
lgtlongroof Posted June 19, 2016 Author Share Posted June 19, 2016 Hey Max capacity, we did #1 60lbs and #3 100lbs, didnt do the other side. At this point i'm looking at rebuilding the engine. MAP is stock along w/ rest of car. I just bought it 3 months ago from a place in Iowa(live in Wis) put 3k miles on it and don't beat on it. The only other thing i know is that #1 plug was NGK and different from #3 plug. So i'm thinking someone knew about the low squeeze etc and tried to make it work to sell. Oh well got a good deal on car and will keep. Thanks for your input and take care JA. Link to comment Share on other sites More sharing options...
lgtlongroof Posted June 19, 2016 Author Share Posted June 19, 2016 One other thing, my friend looked in the #1 hole w/ his scope and said their were score marks on piston ( like something went threw it)Thanks again JA. Link to comment Share on other sites More sharing options...
Max Capacity Posted June 19, 2016 Share Posted June 19, 2016 You'll want to read my click here link and see what it takes to put a ej257 short block in. 305,600miles 5/2012 ej257 short block, 8/2011 installed VF52 turbo, @20.8psi, 280whp, 300ftlbs. (SOLD). CHECK your oil, these cars use it. Engine Build - Click Here Link to comment Share on other sites More sharing options...
