Noobaroo Posted June 13, 2016 Share Posted June 13, 2016 So after driving with the Perrin SSA and Weighted Raceseng shift knob for a while, I think it's worth trying out the weighted Boomba SSA. The shifts aren't bad, but I feel they could be smoother. I recall not feeling great about reinstalling the stock roll pin after wailing on it for quite some time and deforming the end a bit - does anyone have a part number or link to a replacement "double" roll pin? I'm assuming it might be something I could find at a hardware store, but I don't want to try to match it after taking it out of the car. Thanks. Link to comment Share on other sites More sharing options...
foxrider28 Posted June 14, 2016 Share Posted June 14, 2016 Here's a link to the diagram view of the MT shifter fork and rails http://parts.subaru.com/a/Subaru_2010_Legacy25L-TURBO-6MT-4WDGT-Limited-Sedan/_52445_6027529/MT--SHIFTER-FORK--SHIFTER-RAIL-RIVERSE-CHECKING/B14-130-01.html. And you can find almost all your OEM parts on there. I believe that pin is PN 804006210 or (E00621) there's actually 3 used in that linked diagram as well as a smaller one. It's also used on over 850 different models so the dealer should have plenty on hand and I'm sure you could find one at a hardware store. Link to comment Share on other sites More sharing options...
Noobaroo Posted June 14, 2016 Author Share Posted June 14, 2016 That's the one! I tried looking through diagrams but couldn't find this one. Perfect, thanks! Link to comment Share on other sites More sharing options...
