SlowSWP2.5 Posted June 10, 2016 Share Posted June 10, 2016 I own a 2007 legacy 2.5i and I have a check engine light on and my idle is rough. It idles at just above 0 at idle and almost stalls. In reverse it does stall. So I brought it to a shop and they pulled the code. PO506 idle control system low. They said I need to replace the IAC sensor, but I can't find the part anywhere online or a write up about it. I researched this and there is no info on how to replace it for my year legacy. I did read that this year model doesn't have an IAC sensor which I don't know if it is true or not. Any help is appreciated. Link to comment Share on other sites More sharing options...
Max Capacity Posted June 15, 2016 Share Posted June 15, 2016 http://people.csail.mit.edu/ilh/vacation/ If it has one, it will be in the service manual. 305,600miles 5/2012 ej257 short block, 8/2011 installed VF52 turbo, @20.8psi, 280whp, 300ftlbs. (SOLD). CHECK your oil, these cars use it. Engine Build - Click Here Link to comment Share on other sites More sharing options...
