fahr_side Posted June 18, 2016 Share Posted June 18, 2016 You can install the later motor. Block the secondary air ports as suggested. If you have EGR on the original block those too. Use the oil lines that come with the WRX motor. The later heads have smaller combustion chambers. While CR is the same the engine needs, and will tolerate, less timing. Maps developed for the earlier motor will likely knock. The later heads like about 1 to 1.5* less timing overall. Sent from a device using some software. Obligatory '[URL="http://legacygt.com/forums/showthread.php/2008-gh8-238668.html?t=238668"]build thread[/URL]' Increased capacity to 2.7 liters, still turbo, but no longer need spark plugs. Link to comment Share on other sites More sharing options...
kmoleg05 Posted June 18, 2016 Author Share Posted June 18, 2016 I will be getting everything minus the turbo. I have a vf52. So i will basically just drop this entire motor in.. i was wondering if all the plugs and things will work. Im not planning on swapping heads i have a guy that wants my longblock now i want this to be as simple as possible. Ps what's a fair price for longblock with good heads and bad rings? Link to comment Share on other sites More sharing options...
fahr_side Posted June 19, 2016 Share Posted June 19, 2016 I'd get both wiring diagrams out and check the pin outs on the main engine harness. Worst case scenario, you reuse your old harness. Sent from a device using some software. Obligatory '[URL="http://legacygt.com/forums/showthread.php/2008-gh8-238668.html?t=238668"]build thread[/URL]' Increased capacity to 2.7 liters, still turbo, but no longer need spark plugs. Link to comment Share on other sites More sharing options...
kmoleg05 Posted June 20, 2016 Author Share Posted June 20, 2016 Im hoping that we will be able to just plug and play with this motor, but only time will tell. Thanks for the input! Link to comment Share on other sites More sharing options...
fahr_side Posted June 20, 2016 Share Posted June 20, 2016 Well, as they say... hope dies last Obligatory '[URL="http://legacygt.com/forums/showthread.php/2008-gh8-238668.html?t=238668"]build thread[/URL]' Increased capacity to 2.7 liters, still turbo, but no longer need spark plugs. Link to comment Share on other sites More sharing options...
kmoleg05 Posted June 20, 2016 Author Share Posted June 20, 2016 ohh its to early for inspirational quotes... I have attempted to compare pin-outs and believe i found them to be the same.. buuuut I am probably wrong. Link to comment Share on other sites More sharing options...
fahr_side Posted June 20, 2016 Share Posted June 20, 2016 Haha. Just take your time. I call my GH8 a short-wheelbase gen4.5 LGT hatchback. So much in common. But, the LGT also changed a lot between '05 and '08. Sent from a device using some software. Obligatory '[URL="http://legacygt.com/forums/showthread.php/2008-gh8-238668.html?t=238668"]build thread[/URL]' Increased capacity to 2.7 liters, still turbo, but no longer need spark plugs. Link to comment Share on other sites More sharing options...
kmoleg05 Posted June 20, 2016 Author Share Posted June 20, 2016 well a shop is doing the swap so hopefully it goes smoothly Link to comment Share on other sites More sharing options...
fahr_side Posted June 21, 2016 Share Posted June 21, 2016 We should do a wiki on swaps as more owners start looking at motors from the Impreza and Forester lines as time goes on. Sent from a device using some software. Obligatory '[URL="http://legacygt.com/forums/showthread.php/2008-gh8-238668.html?t=238668"]build thread[/URL]' Increased capacity to 2.7 liters, still turbo, but no longer need spark plugs. Link to comment Share on other sites More sharing options...
kmoleg05 Posted June 22, 2016 Author Share Posted June 22, 2016 yea that info would sure be helpful. Just to have a resource of what motors swap in and the general process and difficulty of each swap. Then the individual could find the best option for their budget. Link to comment Share on other sites More sharing options...
