05legacygtr Posted May 28, 2016 Share Posted May 28, 2016 Where are you buying yours? I found one for like 57 bucks, is there anywhere cheaper? I still have the 10 micron filter for my bnr 18g and definitely need to change it out, I'm just a cheap skate with an expensive hobby ha Sent from my SAMSUNG-SM-G920A using Tapatalk Link to comment Share on other sites More sharing options...
rhino6303 Posted May 28, 2016 Share Posted May 28, 2016 Where are you buying yours? I found one for like 57 bucks, is there anywhere cheaper? I still have the 10 micron filter for my bnr 18g and definitely need to change it out, I'm just a cheap skate with an expensive hobby ha Sent from my SAMSUNG-SM-G920A using Tapatalk I'm not sure where to get it cheaper but does your 10 micron have a 10 stamped on it? Link to comment Share on other sites More sharing options...
utc_pyro Posted May 28, 2016 Share Posted May 28, 2016 That's about as low as they get. There are a few others out there but they don't have the same junk capacity. Link to comment Share on other sites More sharing options...
05legacygtr Posted May 29, 2016 Author Share Posted May 29, 2016 I'm not sure where to get it cheaper but does your 10 micron have a 10 stamped on it? I'll have to look when I get out of class, I'll let you know though. Sent from my SAMSUNG-SM-G920A using Tapatalk Link to comment Share on other sites More sharing options...
05legacygtr Posted May 29, 2016 Author Share Posted May 29, 2016 That's about as low as they get. There are a few others out there but they don't have the same junk capacity. thanks for looking man, I'm just planning on buying a few so I don't have to for a while, so every buck counts. Sent from my SAMSUNG-SM-G920A using Tapatalk Link to comment Share on other sites More sharing options...
utc_pyro Posted May 29, 2016 Share Posted May 29, 2016 thanks for looking man, I'm just planning on buying a few so I don't have to for a while, so every buck counts. Sent from my SAMSUNG-SM-G920A using Tapatalk Just got a BNR 16g so looking for the same reason. You can clean them, so you don't really need more than one. Link to comment Share on other sites More sharing options...
05legacygtr Posted June 1, 2016 Author Share Posted June 1, 2016 Just got a BNR 16g so looking for the same reason. You can clean them, so you don't really need more than one. right on, that's good to hear then. There is definitely a 10 stamped on mine. Sent from my SAMSUNG-SM-G920A using Tapatalk Link to comment Share on other sites More sharing options...
