Smithcraft Posted May 27, 2016 Share Posted May 27, 2016 Hello! So I think I nearly have my turbo out, to send to JMP, for some preventative loving. I'm using wcbjr's walkthough for this. At this point, nearly everything is disconnected except for the lower coolant hose, the vacuum line to the wastegate, the inlet, and the oil return fitting. I think... I'm having a problem with getting the lower coolant hose to come off. I can release the clamp, but since there is that metal protection around the hose, I can't slide the clamp off of the end. So I have to try to hold the clamp open, and try and work the hose off. This is not working. So, unless I'm messing with the wrong hose, is there a way to get that hose off of the connector? Thanks! SC 1994 Legacy MI 2008 Legacy GT specB 2023 Crosstrek Limited Link to comment Share on other sites More sharing options...
Smithcraft Posted May 28, 2016 Author Share Posted May 28, 2016 Vacation pics show it as fourteen simple steps. Le Sigh... SC 1994 Legacy MI 2008 Legacy GT specB 2023 Crosstrek Limited Link to comment Share on other sites More sharing options...
Smithcraft Posted May 28, 2016 Author Share Posted May 28, 2016 Since the replacement hose is about $15, I'm just going to cut that damn thing! SC 1994 Legacy MI 2008 Legacy GT specB 2023 Crosstrek Limited Link to comment Share on other sites More sharing options...
Smithcraft Posted May 28, 2016 Author Share Posted May 28, 2016 This link for part numbers: http://legacygt.com/forums/showpost.php?p=3204156&postcount=5 SC 1994 Legacy MI 2008 Legacy GT specB 2023 Crosstrek Limited Link to comment Share on other sites More sharing options...
JmP6889928 Posted May 28, 2016 Share Posted May 28, 2016 Hold the clamp open with needlenose vice grips and grab and twist the hose with regular pliers to get it to turn. Slip it off and slip the clamp off the end. Link to comment Share on other sites More sharing options...
Bochim Posted May 28, 2016 Share Posted May 28, 2016 The first time I took mine off they were difficult too. Link to comment Share on other sites More sharing options...
Smithcraft Posted June 4, 2016 Author Share Posted June 4, 2016 I went and picked up the small size vise grips, and using a long screwdriver, uh prybar, and tugging, it came off. All that was left was the lower oil hose, the inlet, and the two vacuum fittings. So it's hopefully completely drained, and will be getting packed up and shipped to Michigan directly! SC 1994 Legacy MI 2008 Legacy GT specB 2023 Crosstrek Limited Link to comment Share on other sites More sharing options...
Gex Posted June 5, 2016 Share Posted June 5, 2016 For future reference one of these hose hooks can save you a shit ton of agony. [ame=http://www.amazon.com/OTC-4521-Hose-Removal-Tool/dp/B0050SFZBG]Amazon.com: OTC 4521 Hose Removal Tool: Automotive[/ame] Also one of these is nice. I still use the hook more but the seperator pliers work pretty well. [ame=http://www.amazon.com/OTC-4522-Stinger-Vacuum-Removal/dp/B000F5HUQW]Amazon.com: OTC 4522 Stinger Vacuum Hose and Fuel Line Removal Tool: Automotive[/ame] Link to comment Share on other sites More sharing options...
Smithcraft Posted June 6, 2016 Author Share Posted June 6, 2016 I've seen a similar tool, as the hose removal tool, used for the inlet in some YouTube videos. I also used a brake tool for extra leverage, but the super long screwdriver, uh, prybar, worked better. SC 1994 Legacy MI 2008 Legacy GT specB 2023 Crosstrek Limited Link to comment Share on other sites More sharing options...
