turbine crack - how concerning?
How concerning is this crack in the wastegate seat?
http://i85.photobucket.com/albums/k62/dil222/20160520_174707.jpg
Supposedly a lot of VF turbos have this crack in the seat.
For years I've been chasing a 4-600rpm change in spool as temps move past 70 deg. My wastegate flapper was also shifted, but I can't help to wonder if the increased temp caused just enough expansion in the metal to cause later spool.
As I'm looking at this, the crack is in the direct path of the unsmooth portion of the wastegate flow. I may grab my carbide bit and smooth that out. I should smooth the step in the turbine outlet as well.
I have my other thread as well, I'm guessing the shifted flapper was my biggest late boost problem. http://legacygt.com/forums/showthread.php/rattlesnake-sound-under-boost-245193.html
I did some closer inspection this morning. It has at least 4 more cracks. One under the wastegate arm, a second parallel to the first in the seat (if it keeps going the seat will crack out), and two more back by the turbine wheel exit. This housing has had a good life, 150k rocking miles. Despite the cracks and wastegate shifting, it was still making great power. I'm going to replace the housing and put it all back together.
PM JmP6889928, he's our "go to guy" for those type questions.
Seems I've been typing that a lot lately.
Engine Build - Click Here
