MasAyinde Posted May 18, 2016 Share Posted May 18, 2016 I was reading over the instructions for installing the Spec B steering wheel controls, and the guy was installing it using a P-201UH. I believe that this is the reason that new wires had to be run, because looking at the 2007 wiring diagram with the P-204UH, there doesn't seem to be any need to run those wires because the connection already exists. Has anyone installed the SWAC in a 2007 before that can attest to this? Link to comment Share on other sites More sharing options...
MasAyinde Posted May 24, 2016 Author Share Posted May 24, 2016 ...nobody with a non Spec B 2007 has installed a Spec B steering wheel? Link to comment Share on other sites More sharing options...
SVXdc Posted June 6, 2016 Share Posted June 6, 2016 If your 2007 did not have audio SWCs from the factory, a segment of the SWC wires is missing between the steering column and the 8-pin i85 harness plug. I cover that in more detail in trabbic's thread. 2008 and 2009 Legacy/Outback models (where Subaru switched to a different steering wheel, with the cruise buttons on the right hand spoke) are completely pre-wired between the wheel and i85. Link to comment Share on other sites More sharing options...
MasAyinde Posted June 6, 2016 Author Share Posted June 6, 2016 I actually got it working with the help of some of your posts in other threads. I'm now running a 2008 STI steering wheel with working audio and cruise controls Link to comment Share on other sites More sharing options...
