kawasakikl Posted May 11, 2016 Share Posted May 11, 2016 What do you all think? I put a whole new timing set on it, Gates brand, including tensioner, could it be the tensioner? I noticed when I pulled the pin on the tensioner, it didn't move and I could simply put the pin back in. Stethoscope couldn't localize the sound, sounds like it's coming from harmonic balancer area. Link to comment Share on other sites More sharing options...
GEE-OTTO Posted May 11, 2016 Share Posted May 11, 2016 Did you reuse your original timing set? (Pulleys, etc) Link to comment Share on other sites More sharing options...
RustyRuu Posted May 11, 2016 Share Posted May 11, 2016 skip to the end Link to comment Share on other sites More sharing options...
kawasakikl Posted May 11, 2016 Author Share Posted May 11, 2016 Did you reuse your original timing set? (Pulleys, etc) Everything is new on timing set, minus cams and crank pulley. I also replace the accessory belt tensioner pulley. Link to comment Share on other sites More sharing options...
kawasakikl Posted May 11, 2016 Author Share Posted May 11, 2016 skip to the end Youtube is blocked at work. I will watch it later today. Thanks Link to comment Share on other sites More sharing options...
fotofan Posted May 11, 2016 Share Posted May 11, 2016 It's very likely a problem with the Gates tensioner; see this thread for more info. I put something here like all the cool people, except there's nothing cool to put here. Link to comment Share on other sites More sharing options...
kawasakikl Posted May 11, 2016 Author Share Posted May 11, 2016 Hmmm, always found Gates to be decent... Really puzzled me when I removed the grenade pin and could reinsert it without force. I really wish these weren't interference engines. I will inspect my OEM tensioner and reinstall if it's the problem. Is there a way to unstick the gates tensioner? Link to comment Share on other sites More sharing options...
fotofan Posted May 11, 2016 Share Posted May 11, 2016 Yeah see Gates used to be great but they've recently started cutting corners it seems. I put something here like all the cool people, except there's nothing cool to put here. Link to comment Share on other sites More sharing options...
kawasakikl Posted May 11, 2016 Author Share Posted May 11, 2016 Yeah see Gates used to be great but they've recently started cutting corners it seems. Apparently! Hoping my tensioner is bad! Just got off chat with Amazon. They issued a full refund for the entire timing kit (~$116) and I don't have to return it. This is why I shop with Amazon. Maybe I can just replace the tensioner with my old one and drive on? We'll see. Link to comment Share on other sites More sharing options...
fotofan Posted May 11, 2016 Share Posted May 11, 2016 Well yay for Amazon! You should be fine with another tensioner, unless it skipped a significant number of teeth which isn't hugely likely. I put something here like all the cool people, except there's nothing cool to put here. Link to comment Share on other sites More sharing options...
RumbleRumble Posted May 12, 2016 Share Posted May 12, 2016 I have a knock or tap also.I have a gates tensioner on right I'm going to find out tomorrow if mine is bad only been on the car for 1.5years and 13k miles on. Will replace with a Subaru(ntn) if it is bad Link to comment Share on other sites More sharing options...
