Thursday7 Posted May 10, 2016 Share Posted May 10, 2016 08 Legacy GT. VF52. About to switch to some IAG oil lines. I noticed that there is a difference in banjo bolts between the turbo, avcs, and supply on the head, with the turbo having a small, restrictive hole. I did not know there was a difference and was running a big-holed banjo for all 3. For the record, I plan on removing the screen filters in each one. Is there anything detrimental to running too big of a banjo fitting to the turbo? Is there a such thing as too much oil flow? Should I buy an OEM oil restrictor banjo bolt? Thanks. Link to comment Share on other sites More sharing options...
rhino6303 Posted May 10, 2016 Share Posted May 10, 2016 08 Legacy GT. VF52. About to switch to some IAG oil lines. I noticed that there is a difference in banjo bolts between the turbo, avcs, and supply on the head, with the turbo having a small, restrictive hole. I did not know there was a difference and was running a big-holed banjo for all 3. For the record, I plan on removing the screen filters in each one. Is there anything detrimental to running too big of a banjo fitting to the turbo? Is there a such thing as too much oil flow? Should I buy an OEM oil restrictor banjo bolt? Thanks. Yes, yes and yes. Too much flow will float the bearings and toast your turbo. You should buy a new bolt with the correct size oil control orifice. Link to comment Share on other sites More sharing options...
Thursday7 Posted May 10, 2016 Author Share Posted May 10, 2016 Thank you! Link to comment Share on other sites More sharing options...
