stikiller Posted May 3, 2016 Share Posted May 3, 2016 What can cause my flex plate to rub on the engine bell housing? I've looked at the casting and couldn't find where it is rubbing. Only solution I can think of is to grind a couple of the casting ribs down but I would like to know the cause of it if possible. Any thoughts or experience with this? Link to comment Share on other sites More sharing options...
Max Capacity Posted May 3, 2016 Share Posted May 3, 2016 The plate must not be seated correctly on the crank shaft. 305,600miles 5/2012 ej257 short block, 8/2011 installed VF52 turbo, @20.8psi, 280whp, 300ftlbs. (SOLD). CHECK your oil, these cars use it. Engine Build - Click Here Link to comment Share on other sites More sharing options...
stikiller Posted May 3, 2016 Author Share Posted May 3, 2016 Yeah I don't know I think it was unless the big washer ring that goes around the crank that was on the torque converter side is supposed to be on the crank side? Link to comment Share on other sites More sharing options...
Max Capacity Posted May 3, 2016 Share Posted May 3, 2016 I'm not really up on how 5eat's go together. It doesn't make sense to put the washer behind the flex plate, the washer should go under the bolt heads. I gather your doing this with the engine out of the car ? Step back for a minute, look things over...it should be something simple. 305,600miles 5/2012 ej257 short block, 8/2011 installed VF52 turbo, @20.8psi, 280whp, 300ftlbs. (SOLD). CHECK your oil, these cars use it. Engine Build - Click Here Link to comment Share on other sites More sharing options...
