wraedeohed Posted April 27, 2016 Share Posted April 27, 2016 Hello good people, Good any one of you fine ladies and gents point me in the direction of a walk-through or DIY of replacing the the rear-view camera? It'd be much appreciated. Link to comment Share on other sites More sharing options...
FAILBOT Posted April 27, 2016 Share Posted April 27, 2016 If I had one on mine I could do that for you. Unfortunately I don't. Are you trying to just do an oem replacement or replace with aftermarket? Link to comment Share on other sites More sharing options...
GTEASER Posted April 27, 2016 Share Posted April 27, 2016 It should be pretty straight forward. Pop the trunk, remove the pop-its for the inside trunk trim, unplug, unbolt, remove, install new in reverse order. GTEASER's 2012 Legacy GT - Sold GTEASER's 2009 XTeaser - Sold GTEASER's 1992 Legacy SS - Sold Link to comment Share on other sites More sharing options...
wraedeohed Posted April 28, 2016 Author Share Posted April 28, 2016 OEM, I think I just need the camera module replaced. The trigger works and I get all the on screen proximity lines, but no image. Sent from my XT1096 using Tapatalk Link to comment Share on other sites More sharing options...
wraedeohed Posted April 28, 2016 Author Share Posted April 28, 2016 Any idea where I can find a replacement camera module? I've checked eBay and Amazon, but I'm not really sure which will work. Sent from my XT1096 using Tapatalk Link to comment Share on other sites More sharing options...
GTEASER Posted April 28, 2016 Share Posted April 28, 2016 If you have the OEM camera easiest solution would be to replace it with another OEM one, otherwise you have to get into changing connectors, etc. GTEASER's 2012 Legacy GT - Sold GTEASER's 2009 XTeaser - Sold GTEASER's 1992 Legacy SS - Sold Link to comment Share on other sites More sharing options...
FAILBOT Posted April 28, 2016 Share Posted April 28, 2016 Salvage yard or dealership would be my best guess. Link to comment Share on other sites More sharing options...
cww516 Posted April 28, 2016 Share Posted April 28, 2016 It may have also just come unplugged or have a loose/damaged wire or terminal, pretty sure the lines are added in by the head unit rather than by the camera. Could be worth jiggling some wires before you go and buy a replacement. Link to comment Share on other sites More sharing options...
wraedeohed Posted September 17, 2016 Author Share Posted September 17, 2016 I may make a walk through for this shortly Link to comment Share on other sites More sharing options...
