mr_silas Posted April 22, 2016 Share Posted April 22, 2016 My car recently died while driving and im having trouble finding the problem. It threw a p0108 but the car wont start. Just turn over. I than found my throttle body tube was disintegrated. And my Throttle body was making a loud electrical buzzing noise. My guess is the loose hose made the TPS sensor go bad and or the TB motor or something isnt working. here is a link to pictures and a video with the sound its making https://goo.gl/photos/yzcywjaNqza51QY69 Anywho i was wondering if you guys could tell me what other model.... -Throttle bodies -TPS's -MAP's -Manifold's -Fuel pump's .....will fit my car i know an ej255 is a ej255 but it seems that some parts dont directly go over from say a sti or wrx or xt. and im having trouble finding a detailed list of things will that will. Any help is appreciated! Thanks Link to comment Share on other sites More sharing options...
Phillip J. Fry Posted April 23, 2016 Share Posted April 23, 2016 why do you look for parts from a wrx or sti? do you not know your 05 is basically an sti engine with a few changes? the only thing you should take from a wrx is the vf52. just get a new coupler and see how it goes. get a sillycorn coupler from a reputable company. Link to comment Share on other sites More sharing options...
mr_silas Posted April 23, 2016 Author Share Posted April 23, 2016 Yes I do know that. That's why I'm asking what those few changes are. Alright I can give that a shot. Link to comment Share on other sites More sharing options...
mr_silas Posted April 23, 2016 Author Share Posted April 23, 2016 Nvm just found out my timing belt snapped Link to comment Share on other sites More sharing options...
Phillip J. Fry Posted April 25, 2016 Share Posted April 25, 2016 Nvm just found out my timing belt snapped that suuuuuuuuuckkkksssss seems i misunderstood your post a bit. the parts you listed seems perfectly fine on the legacy. my tuner recommended a DW65. but im prepping for a vf52. on stock turbo the stock pump is fine. everything you listed stock on the car are perfectly fine afaik. Link to comment Share on other sites More sharing options...
Max Capacity Posted April 25, 2016 Share Posted April 25, 2016 Was the engine running when belt snapped ? If so that's not good. you have bent valves. 305,600miles 5/2012 ej257 short block, 8/2011 installed VF52 turbo, @20.8psi, 280whp, 300ftlbs. (SOLD). CHECK your oil, these cars use it. Engine Build - Click Here Link to comment Share on other sites More sharing options...
chucks06LGT Posted April 26, 2016 Share Posted April 26, 2016 Sounds like it, OP mentioned in his post that the engine died while driving.... Link to comment Share on other sites More sharing options...
