nadeaa0a Posted April 19, 2016 Share Posted April 19, 2016 Hello everyone, I'm a little bit frustrated with my 2002 Subaru Legacy 2.5 NA as the exhaust system has absolutely no O2 sensors at all. I looked everywhere and couldn't find any sensors or even holes. My car is not a USDM specs (it's a JDM spec) and what is driving me crazy is that i have a CEL and the ECU is throwing those two codes: P0037 and P0031. After doing some research, it seems like both codes point to a problem with the O2 sensors that don't even exist. Can someone shed some light on what exactly is going on? Note: My car is 100% stock with no mods and I've owned it for a long time and never had problems with CEL until this time. Link to comment Share on other sites More sharing options...
GEE-OTTO Posted April 20, 2016 Share Posted April 20, 2016 So the AFR sensor is a little bit different than the actual 02 sniffer sensor. IF you are throwing those codes you may be running rich. If its fuel injected it has a sensor somewhere. On the JDM models it should be in the cat section and if so its the one closets to the engine. Link to comment Share on other sites More sharing options...
