wayne1998 Posted April 18, 2016 Share Posted April 18, 2016 Does anyone offer a kit to convert the AC, Thanks Link to comment Share on other sites More sharing options...
GTEASER Posted April 18, 2016 Share Posted April 18, 2016 I think EnviroSafe makes a refridgerant that's compatable with both R12 and R134 so you can use it versus converting all your seals and compressor. GTEASER's 2012 Legacy GT - Sold GTEASER's 2009 XTeaser - Sold GTEASER's 1992 Legacy SS - Sold Link to comment Share on other sites More sharing options...
mnstrmech Posted April 19, 2016 Share Posted April 19, 2016 I may get flamed... I dont care... Im ASE certified.... but i simply changed the reciever drier on mine and charged with R134, minus 20% of the system capacity.. and been going strong and cold for over 3 years... still have the original compressor. The center temp vent gets into low 40's.. sometimes upper 30's, degrees that is. Changing out all the seals and compressor is not necessary as once believed... Link to comment Share on other sites More sharing options...
wayne1998 Posted April 19, 2016 Author Share Posted April 19, 2016 I was planning on the same, keep everything original and just add R134. I just need to change the fittings is that correct??? Do I need to change the drier? If so why? Thanks Link to comment Share on other sites More sharing options...
mnstrmech Posted April 19, 2016 Share Posted April 19, 2016 The receiver/drier has a desiccant bag that holds oil that filters out the moisture inside the system... so changing out freon you would change the drier as well.... pouring in oil for 134 refrigerant... then both fittings... and important... only charge 80% of system capacity... Link to comment Share on other sites More sharing options...
