jcarne19 Posted April 12, 2016 Share Posted April 12, 2016 Hello everyone, I am very new to this forum (like today new) and this is my first post. I drive a 2009 2.5i 5MT Legacy SE and I have noticed this whining noise that occurs around 3000 rpm. Its very consistent and is most noticeable when the car is decelerating when I am off the throttle. The sound comes from the front of the car. Initially I thought this was a transmission oil problem because I was 10k miles over the recommended maintenance for the oil . I serviced the oil this past weekend but the noise still persists. Does anyone know what this is? Is it something I should be concerned about? Thanks! Link to comment Share on other sites More sharing options...
bomberlegacy Posted April 12, 2016 Share Posted April 12, 2016 Can you post a video of it? '08 Legacy 2.5i - hybrid intake - delta 1000 - E85 - magnaflow exhaust Link to comment Share on other sites More sharing options...
Ugh. Posted April 12, 2016 Share Posted April 12, 2016 I've heard a whining/whistles noise on my car before and I thought it was strange since the car didn't have any forced induction, so I did some research online and found out apparently the intake likes to whistle from time to time. Could be that but don't take my word for it. Link to comment Share on other sites More sharing options...
apexi Posted April 13, 2016 Share Posted April 13, 2016 Is it the sound you hear at 17 seconds in my video below? You can also hear it again at around 58 seconds or so. It's not really a whining I hear there, more like a rush of air, but you never know. https://youtu.be/LxPb92p-MJA Link to comment Share on other sites More sharing options...
jcarne19 Posted April 13, 2016 Author Share Posted April 13, 2016 Maybe whining isn't the proper term to describe it because I don't believe it has to do with air or the intake. I'll try to get a video of the sound today and post it here. Link to comment Share on other sites More sharing options...
HiPowerShooter Posted April 14, 2016 Share Posted April 14, 2016 Often times MT's make a bit more noise simply due to the reduced amount of metal/fluid within the assembly to absorb it in comparison to their AT brother. The gear to gear contact is most pronounced on both acceleration and de-acceleration when the teeth are taking the most load. MT's have only a thin film of gear oil in comparison to the gallons of AT fluid and all of the clutch packs within the case. You'll hear it more while slowing down due to the fact you don't have the noise of the engine/exhaust as it is making power. Link to comment Share on other sites More sharing options...
jcarne19 Posted April 15, 2016 Author Share Posted April 15, 2016 I haven't been able to get a good video and it's hard to hear the sound. I have had a hunch that it might just be the sound of manual transmissions, but it does seem quiet loud to just be that. Maybe I'll do some more investigation Link to comment Share on other sites More sharing options...
RumbleRumble Posted April 16, 2016 Share Posted April 16, 2016 Does it ever happen at idle? Link to comment Share on other sites More sharing options...
jcarne19 Posted April 17, 2016 Author Share Posted April 17, 2016 Sometime it will happen when I start the car up and let it idle for a few seconds then it will go away Link to comment Share on other sites More sharing options...
GEE-OTTO Posted April 18, 2016 Share Posted April 18, 2016 Given its a 5MT and a Subaru I'll say your car is operating fine to be 7-8 years old at this point when new they make odd noises here and there so after a few years and miles it may increase. Rattles and squeaks are "normal", scraping or knocking is bad. It could be a failing bearing on the timing set, your PS pump, alternator or anything that rotates via belt in the engine. Keep and ear out for it and keep up posted. Welcome Link to comment Share on other sites More sharing options...
jcarne19 Posted April 28, 2016 Author Share Posted April 28, 2016 If anyone is still following this thread I was able to get a good video when I started the car: You can hear it from 0:09-0:16 Link to comment Share on other sites More sharing options...
GEE-OTTO Posted April 29, 2016 Share Posted April 29, 2016 That sound like an exhaust leak + heat shield rattle. Keep in mind during idle the mix is slightly rich to heat the cats up to light temp then leans out for normal operation, that contributes to the louder cold idle. There is something vibrating under there that makes it sound waaay worse. Overall its very normal idle Link to comment Share on other sites More sharing options...
