Shogun506 Posted April 11, 2016 Share Posted April 11, 2016 Does anyone have a part number for flywheel bolts for the Legacy GT? Also, if I'm using a SMFW from the Exedy OEM replacement kit, should I be using the stock 05 DMFW bolts or are there different bolts for the SMFW equipped cars that I should use? Part number for those? I seem to be finding this part number in a lot of places: #800610740 http://www.oakos.com/Merchant2/merchant.mvc?Screen=PROD&Store_Code=355&Product_Code=800610740&Category_Code= But I don't see Legacy listed there. Link to comment Share on other sites More sharing options...
Shogun506 Posted April 12, 2016 Author Share Posted April 12, 2016 I may have answered my own question here but if anyone can confirm that 800410070 (different from that first link) is the right part that would be helpful Link to comment Share on other sites More sharing options...
Max Capacity Posted April 12, 2016 Share Posted April 12, 2016 Go to the dealership parts guy and tell them you want single mass flywheel bolts for a 2007-2009 Legacy GT. They will be the same a WRX from the same year. 305,600miles 5/2012 ej257 short block, 8/2011 installed VF52 turbo, @20.8psi, 280whp, 300ftlbs. (SOLD). CHECK your oil, these cars use it. Engine Build - Click Here Link to comment Share on other sites More sharing options...
Shogun506 Posted April 12, 2016 Author Share Posted April 12, 2016 I just ordered them. I always like to confirm somewhere else before I order a part, especially when it's different than what's originally meant for the car. Link to comment Share on other sites More sharing options...
Max Capacity Posted April 12, 2016 Share Posted April 12, 2016 Understand, but this is such a common swap. It's really easy to get it right. 305,600miles 5/2012 ej257 short block, 8/2011 installed VF52 turbo, @20.8psi, 280whp, 300ftlbs. (SOLD). CHECK your oil, these cars use it. Engine Build - Click Here Link to comment Share on other sites More sharing options...
jwag74 Posted April 16, 2016 Share Posted April 16, 2016 I reused the stock DMFW bolts with my SMFW, no issues. You should be good with either bolts. Link to comment Share on other sites More sharing options...
