FLlegacy Posted April 11, 2016 Share Posted April 11, 2016 http://legacygt.com/forums/showthread.php/koni-shock-strut-epic-engineering-spring-install-145744.html You need the spring seat to bottom out on the strut rod shoulder, so you need to compress the spring more. Link to comment Share on other sites More sharing options...
FLlegacy Posted April 11, 2016 Share Posted April 11, 2016 Are you sure you have the correct struts? Link to comment Share on other sites More sharing options...
FAILBOT Posted April 11, 2016 Author Share Posted April 11, 2016 Yes, correct struts. Same numbers as GTEASER's build. I looked over that post and made a few adjustments to mine. Gonna do the other side as well and test. Shaft still doesn't go all the way through, but it is physically impossible to and since it matches the factory strut then that must be how it is. I've also moved the camber back as close to factory mark as well it was off just a bit. Will do other side and report back. Link to comment Share on other sites More sharing options...
FAILBOT Posted April 11, 2016 Author Share Posted April 11, 2016 http://legacygt.com/forums/showthread.php/koni-shock-strut-epic-engineering-spring-install-145744.html You need the spring seat to bottom out on the strut rod shoulder, so you need to compress the spring more. Ok, problem resolved as far as I can tell. Link above helped a lot. I must have had some sort of misalignment in my upper spring perch and possibly that along with camber adjustment. I followed links steps and corrected camber to factory position. No more bad sounds BUT, the shaft still sits down in the bearing a bit. This must be normal as it's just impossible to go through more. Much thanks to everybody for all their help. This is the second night out in the garage for hours after doing turn arounds at work. I'm wipped and appreciate the speedy replies! Link to comment Share on other sites More sharing options...
FLlegacy Posted April 11, 2016 Share Posted April 11, 2016 Thanks for posting your resolution since I am sure someone else will undoubtedly have the same issue. Link to comment Share on other sites More sharing options...
DugsSin Posted April 11, 2016 Share Posted April 11, 2016 Completely forgot about the thread from Fred Beans . I printed out the important pages to be kept with GTeasers info for quick reference. Link to comment Share on other sites More sharing options...
GTEASER Posted April 11, 2016 Share Posted April 11, 2016 Did you drill out the opening on the tophats so the strut rod would clear all the way thru? Only for the 2 rears, drilled out to 12mm or 31/64". GTEASER's 2012 Legacy GT - Sold GTEASER's 2009 XTeaser - Sold GTEASER's 1992 Legacy SS - Sold Link to comment Share on other sites More sharing options...
GTEASER Posted April 11, 2016 Share Posted April 11, 2016 Yes, it's absolutely imperative to get the upper spring seat all the way down on the strut rod shoulder, and then the conical washer (large flat side down) by compressing the spring more and then placing the bearing and tophat on the assembly. Sounds like that was your problem. GTEASER's 2012 Legacy GT - Sold GTEASER's 2009 XTeaser - Sold GTEASER's 1992 Legacy SS - Sold Link to comment Share on other sites More sharing options...
wraedeohed Posted April 12, 2016 Share Posted April 12, 2016 Hey guys,, how much of a difference do different tophats make with the handling? Link to comment Share on other sites More sharing options...
GTEASER Posted April 12, 2016 Share Posted April 12, 2016 Hey guys,, how much of a difference do different tophats make with the handling? Little to none. If the bearing on the front tophats doesn't move smoothly then replace, otherwise you stock ones should be fine. GTEASER's 2012 Legacy GT - Sold GTEASER's 2009 XTeaser - Sold GTEASER's 1992 Legacy SS - Sold Link to comment Share on other sites More sharing options...
