Qckslvr Posted April 10, 2016 Share Posted April 10, 2016 So, my plan is to remove one, maybe two, calipers at a time to completly disassemble them, rebuild, and repaint before installing with new stainless lines. Question is, how do I manage to do this without a) allowing the system to bleed down too low, b) using 30 bottles of brake fluid? Thanks in advance for anyone that has done this and can provide a high-level walkthrough. Link to comment Share on other sites More sharing options...
doobaruGT Posted April 10, 2016 Share Posted April 10, 2016 I had to work on a seized caliper and so I used the banjo and found a nut to cap the line. Use the old crush washers and that should stop the leak enough while you work on the caliper. You may have to check it periodically since the banjo will still allow fluid to pass, but it will be at a much slower rate. Just top off the reservoir if necessary. Sent from my iPad using Tapatalk Updated parts list since original part-out here. Original Full part-out of my LGT HERE! Link to comment Share on other sites More sharing options...
08SpecB_DE Posted April 10, 2016 Share Posted April 10, 2016 When pertaining to the brake hose, you have a couple options. You can buy a pair of hose crimpers that are flat and allow you to pinch the brake hose without chewing into the rubber, or my favorite way, take a regular rubber valve stem, remove the cap and push it into the hole of the hose. Link to comment Share on other sites More sharing options...
DonnyJagaru Posted April 11, 2016 Share Posted April 11, 2016 I thought pinching the brake flex hose was a definite no-no? Link to comment Share on other sites More sharing options...
08SpecB_DE Posted April 12, 2016 Share Posted April 12, 2016 It's not a no-no if you do it properly but I still recommend using a valve stem instead. Your main concern is to not twist the hose or allow the caliper to hang by the hose. Link to comment Share on other sites More sharing options...
quick4dr Posted April 12, 2016 Share Posted April 12, 2016 +1 For tire valve trick, in my time at Acura, my master tech showed me that trick, the rubber of the valve seals it up pretty good. rather then rebuild, just pick up 2 new fronts and paint them, then do a straight swap. My new caliper ran me $100. for passanger front. the time saving of pre painting them and then just doing a swap in might be better for you Link to comment Share on other sites More sharing options...
