jakegoedicke Posted April 7, 2016 Share Posted April 7, 2016 So recently my turbo started leaking oil badly. 4 quarts every 1700 miles. So i got a rebuilt turbo with a billet wheel and installed that along with an invidia uppipe. Yes, i changed oil and banjo bolt screens were removed. i "tuned" it with my apv2. The turbo sounds great. except for one thing, my boost is at 19.5psi... could the billet wheel cause more boost or the uppipe, idk im just confused or did they put a different pill in the rebuilt turbo. i was going to get a pro tune but not right away figured it wouldnt be a huge deal with the ap tune. Link to comment Share on other sites More sharing options...
WahooNo2 Posted April 7, 2016 Share Posted April 7, 2016 is it a new wastegate or the same as the old one? is it the same size turbo as before? Link to comment Share on other sites More sharing options...
KRM Posted April 7, 2016 Share Posted April 7, 2016 Stay out of boost. Or say goodbye to the motor. New turbo other than oem will need a tune. Not a generic over the shelf map made for oem style, not aftermarket. Link to comment Share on other sites More sharing options...
freaksavior Posted April 7, 2016 Share Posted April 7, 2016 Was the billet wheel the same blade design, more blades, less blades? It's likely more blades than the past one, so it's likely pulling in more air. The uppipe. If you had an oe from the 05-06, then it was catted, and the catless will provide more air flow for a faster spool. Link to comment Share on other sites More sharing options...
Shogun506 Posted April 8, 2016 Share Posted April 8, 2016 what OTS tune did you apply? with just an uppipe you shouldn't be on anything more than stage 1 tune Link to comment Share on other sites More sharing options...
jakegoedicke Posted April 8, 2016 Author Share Posted April 8, 2016 I'm on just the stage 1 tune now I have up pipe turbo back and intake. It's the stock turbo. Just has 12 blades I think. Link to comment Share on other sites More sharing options...
jakegoedicke Posted April 8, 2016 Author Share Posted April 8, 2016 The turbo is not upgraded. It's the ihi vf 40 Link to comment Share on other sites More sharing options...
Shogun506 Posted April 8, 2016 Share Posted April 8, 2016 I'm on just the stage 1 tune now I have up pipe turbo back and intake. It's the stock turbo. Just has 12 blades I think. If you have a turbo back you need to have stage 2 tuned. Link to comment Share on other sites More sharing options...
jakegoedicke Posted April 8, 2016 Author Share Posted April 8, 2016 If you have a turbo back you need to have stage 2 tuned. I did have it at that just took it off to see if it would change. It didnt Link to comment Share on other sites More sharing options...
gkinslow Posted April 8, 2016 Share Posted April 8, 2016 Better to get it Protuned and know its right then to continue guessing and possibly NANSB. Link to comment Share on other sites More sharing options...
Phate Posted April 8, 2016 Share Posted April 8, 2016 Better to get it Protuned and know its right then to continue guessing and possibly NANSB. This. Install all mods, get professionally tuned. Have a safe running car that makes the power it's supposed to. Link to comment Share on other sites More sharing options...
