NSFW Posted March 24, 2016 Share Posted March 24, 2016 Can anyone point me to a pinout diagram for the AVCS cam angle sensors? I know the pins are +5v, ground, and signal, I just don't know which pin is which. Thanks! Link to comment Share on other sites More sharing options...
Max Capacity Posted March 24, 2016 Share Posted March 24, 2016 http://people.csail.mit.edu/ilh/vacation/ There not in the service manual ? Look in the back, there is a how things work and flow section. 305,600miles 5/2012 ej257 short block, 8/2011 installed VF52 turbo, @20.8psi, 280whp, 300ftlbs. (SOLD). CHECK your oil, these cars use it. Engine Build - Click Here Link to comment Share on other sites More sharing options...
mondtster Posted March 25, 2016 Share Posted March 25, 2016 Can anyone point me to a pinout diagram for the AVCS cam angle sensors? I know the pins are +5v, ground, and signal, I just don't know which pin is which. Thanks! You don't have a meter to figure it out? Odds are good that power and ground are the outer two pins with the middle being the signal. But, the service manual should have enough detail you can figure it out from there if you don't feel like poking and prodding to figure it out. Link to comment Share on other sites More sharing options...
NSFW Posted March 25, 2016 Author Share Posted March 25, 2016 Thank you both! Checking with a meter is a damn fine idea, I can't believe I didn't think of that. The manual says you're right about the signal being on the middle line, and a meter will tell me which of the other two are which. Link to comment Share on other sites More sharing options...
