TylerHartman's 1999 Legacy GT Wagon 5SPD
  • Replies 140
  • Created
  • Last Reply
Top Posters In This Topic
  • 3 weeks later...
Oil pan came crushed, So started fresh by upgrading to the 06+ STI EJ25 Oil pan, EJ25 Killer B pickup, and Killer B Windage tray. So i'm selling the EJ20 Pickup now ;D
http://i851.photobucket.com/albums/ab78/xbox_360_Reapir/99LGTWGN/00599CDC-8986-46E2-8DE4-DB5FA4ACE6F6.jpg
Pre Black Friday and the fact the engine is out of the car caught me on this. Grimmspeed 38MM Black coated up pipe with Screamer pipe. I bought the Block off plate so I could just run it as an Up-Pipe till tune time.
http://i851.photobucket.com/albums/ab78/xbox_360_Reapir/99LGTWGN/8AC6F25E-5E2D-4CD1-B1BE-0EB2258CC64F.jpg
http://i851.photobucket.com/albums/ab78/xbox_360_Reapir/99LGTWGN/82986E06-4FCC-4C6A-97FA-2B88282965EB.jpg
  • 4 weeks later...
(Update)
Been starting it up for a few mins here and there letting it idle, it's starting up at about 1,500rpm or so at cold start then idles up to 2,000 then kicks down to 1,200. I feel like my CEL's and vac leak are causing this. I need to read CEL's tomorrow but I should have one for TGV's, one for Catless.
I don't want to let it run Open downpipe too long, it's so loud my aunt and uncle that live down the road, actually heard it running lol.
I managed to drain 6-7 Gallons of the old gas out, Got 10 Gallons of BP 93 Octane in there along with a brand new fuel filter. My goals are to clean out the tank as much as possible over the next few months since I plan to be running E85 at some point.
I also managed to grab a JDM BG steering wheel shroud Boost gauge, it'll be a few months till I have it tho.
Also grabbed a VF48 but I'm trying to sell it as Jumped the gun on that.
Waiting on a Tatrix OpenPort 2.0 cable, My Busted finger cable doesn't work with ECU Flash :(
I have 11 Codes total, half are TGV Related, Front O2 A/F, EVAP, TPS
Check list for the car
WRX Throttle cable (Done)
Power Steering return rubber line (Done)
Hoodscoop shroud
finish interior
fill rear diff (Done)
check all subframe bolts etc with TQ Wrench
modify eBay exhaust
Change oil after it's been running for a few hours
  • 2 weeks later...
Nice car! Can't believe I haven't seen this thread. Definitely in for this build.
Thanks! I normally spend my time on SL-I but sadly it's dying breed so i'm spending more time here some more now.
beautiful
Thanks for the kind words )
what wheels are those.
2004 STI BBS's only year they were made in 5x100, rest of the GD STI Wheels we're 5x114.3
With the turbo did you think of going to a TD05?
Would be a nice upgrade and might be cheaper than a VF turbo
I ended up selling that VF48 I bought and ended up making a few bucks in the process so win? haha :D I'll probably just run this TD04HL for a bit, Goal is 1000C Injectors, Turbosmart 40MM EWG, EBCS in the next few weeks then get tuned for that. Considering doing a FPR and rails while I'm at it but We'll see about that..
Already have a Heat Wrapped Catless DP, EWG Up pipe(Blocked off till I get the EWG), 14' STI TMIC, Tomei Turbo Inlet, TGV Delete, Walbro 255LPH, 3" Exhaust
Then Pickup something that could run well on EJ22/EJ25 Block later on, No idea yet..
^ that's what I thought no wonder they are so expensive.
Exactly, they aren't cheap that's for sure :(
http://www.youtube.com/watch?v=mhrBytSUsKI
use just the url without the &feature part, then delete the s in https:// part
[ame=http://www.youtube.com/watch?v=mhrBytSUsKI]Subaru JDM EJ205 AVCS Swapped Legacy GT Open Downpipe - YouTube[/ame]
  • 4 weeks later...
