PhilT Posted March 18, 2016 Share Posted March 18, 2016 Hi, been a while since I've been on the forum, things have been running well and I don't drive so much. Now as the old girl is getting older a few problems have started to arise, and I have one that I just can't trace. Hopefully someone can shed some light....... Driving the car for the first time in a few week, I found that none of the electric windows are working, thankfully they are all closed so it's not a problem. Then when parking the car I remote lock the car and the lights flash but I don't hear the reassuring thunk, so on checking find that none of the doors have locked. This can't be a coincidence, so I pull the wiring diagram and as expected they power is on a common circuit. I have checked all the fuses, none blown. Check the wiring, no obvious breaks, so now I'm stumped. Does anyone know if there is another fuse not shown on the diagram that could cause this? Cheers46 - Keyless Entry System.pdf Double Award Winning Legacy GT Wagon Link to comment Share on other sites More sharing options...
apexi Posted March 18, 2016 Share Posted March 18, 2016 I wonder if something is wrong with the power window/door lock switch inside the car. Can you lock/unlock the car using that switch inside the car? Or does that not work either, like the window buttons? Since both the windows and door locks are routed through that, that's why I think that could be the problem. Link to comment Share on other sites More sharing options...
PhilT Posted March 19, 2016 Author Share Posted March 19, 2016 Thanks, I'll pull the door panel off and see what I can find. Sent from my STV100-3 using Tapatalk Double Award Winning Legacy GT Wagon Link to comment Share on other sites More sharing options...
Mad Ra88it Posted August 15, 2016 Share Posted August 15, 2016 Did anything ever come of this? I've attempted using a different integrated control module, new switch. Short of a new drivers seat, I'm not quite sure how to proceed with this. Link to comment Share on other sites More sharing options...
Max Capacity Posted August 16, 2016 Share Posted August 16, 2016 Most problems like this are cause by the drivers door control switches in the arm reast on the door. I had mine replaced under warranty back in the day, about 60,000 miles. But sounds like you have done that ? http://people.csail.mit.edu/ilh/vacation/ service manual may help. 305,600miles 5/2012 ej257 short block, 8/2011 installed VF52 turbo, @20.8psi, 280whp, 300ftlbs. (SOLD). CHECK your oil, these cars use it. Engine Build - Click Here Link to comment Share on other sites More sharing options...
ehsnils Posted August 17, 2016 Share Posted August 17, 2016 Before you do anything more - check battery voltage. If it's too low then you might get that kind of problem. Link to comment Share on other sites More sharing options...
