shelbay Posted March 15, 2016 Share Posted March 15, 2016 I have done a search but have not found the info I need, hopefully someone can point me in the right direction. I have a 2010 Subaru Legacy 3.6R, which I really enjoy driving. At the end of the summer season in 2015, I noticed that my summer tires, Hankook Ventus V2, were beginning to get pretty loud. The garage I use said the tires appeared to be ok, no uneven wear, cupping, etc. Since it was close enough to winter, I switched to my Michelin X-ice tires, and right away noticed the same annoying road noise from the tires. Since funds were tight I decided to drive it through the winter. The Michelins came with the car when I bought it so, I thought maybe both sets were hardened due to age. I was looking forward to spring so I could get those Michelins off, and today put on a new set of General Altimax RT43 tires. I was very discouraged to find that the noise, although somewhat quieter, is still there. I have had an alignment, there is no pulling left or right, and tire wear is normal. Should I be looking for other causes, wheel bearings, transmission...? Thanks for any insight you can give. Link to comment Share on other sites More sharing options...
Unsp0kn Posted March 15, 2016 Share Posted March 15, 2016 What PSI do you typically run your tires at? Link to comment Share on other sites More sharing options...
shelbay Posted March 15, 2016 Author Share Posted March 15, 2016 I normally run them at the pressure recommended on the factory door sticker. I check the pressures every few weeks. Link to comment Share on other sites More sharing options...
fedaykin Posted March 16, 2016 Share Posted March 16, 2016 Try 36psi and a wheel alignment. Link to comment Share on other sites More sharing options...
08SpecB_DE Posted March 16, 2016 Share Posted March 16, 2016 Could be a bearing or differential. It's hard to tell without hearing it. Is it a faint noise? Does it change pitch if you turn left or right? Link to comment Share on other sites More sharing options...
shelbay Posted March 16, 2016 Author Share Posted March 16, 2016 I had a wheel alignment last year, the tire wear and lack of wandering left or right on the highway make me think the alignment is still ok. The noise does not seem to shift when turning, although I will have to double check on that. The noise sounds like a consistent hum, which increases or decreases with speed, much like a truck with the oversized tires. I have tried putting the car in neutral when driving and the noise does not change. Thanks for some input, I will try the air pressure and also check to see if the noise does change when turning. Link to comment Share on other sites More sharing options...
hkshooter Posted March 16, 2016 Share Posted March 16, 2016 Sounds like a bearing failing by your description. Sent from my SM-G920V using Tapatalk Link to comment Share on other sites More sharing options...
Timothy.B Posted March 16, 2016 Share Posted March 16, 2016 If it gets louder and louder, it's probably a wheel bearing. As soon as you said hum. If it gets louder than the radio, it's close to its end. Edit: I wouldn't advise letting it get to that point Timothy.B's 2011 LEGACY 3.6R Link to comment Share on other sites More sharing options...
shelbay Posted March 16, 2016 Author Share Posted March 16, 2016 Thanks to all of you for the info. After your suggestions, I did some more reading, and I think we are leaning towards wheel bearing. I am making arrangements today to get it checked. Thanks again, this was a big help. Link to comment Share on other sites More sharing options...
