mod boss Posted March 13, 2016 Share Posted March 13, 2016 To a legacy gt I drive a 2006 legacy gt that the engine is nocking An is no good but ,, my buddy gave me a 2001 legacy moter would I be able to swap the block and change the top end of it There both ej25 engines ??!!!!! Sent from my iPhone using Tapatalk Link to comment Share on other sites More sharing options...
Scruit Posted March 13, 2016 Share Posted March 13, 2016 Is the 2001 motor turbo? If not, the compression ratio may be too high. (Turbo engines have a lower CR, assuming they will be under additional compression from the turbo) Link to comment Share on other sites More sharing options...
mod boss Posted March 13, 2016 Author Share Posted March 13, 2016 No 2001 is not a turbo But I thought it would be worth looking into some since there both ej25s and was gonna try to just swap the core out Sent from my iPhone using Tapatalk Link to comment Share on other sites More sharing options...
Max Capacity Posted March 16, 2016 Share Posted March 16, 2016 Try and look at a head gasket from each engine, see if the water jackets match up. 305,600miles 5/2012 ej257 short block, 8/2011 installed VF52 turbo, @20.8psi, 280whp, 300ftlbs. (SOLD). CHECK your oil, these cars use it. Engine Build - Click Here Link to comment Share on other sites More sharing options...
RustyRuu Posted March 16, 2016 Share Posted March 16, 2016 you would have to swap the pistons out to get the proper compression ratio. you would be lucky if you had all the same sizes of pistons. i.e. your gt could be an AAAA motor and the 02 block could be a BBBB block. people do make those blocks though, you will be using a completely open deck though on the 02 block, your gt is semi closed. i know the people that do build those are more of the dune buggie/ sand rail builders. so maybe just search google for subaru sandrails engines or something Link to comment Share on other sites More sharing options...
charlie91 Posted March 29, 2016 Share Posted March 29, 2016 your 06 turbo block has an extra crank case vent and dished pistons, it will not be a direct swap with pcv. Link to comment Share on other sites More sharing options...
SBT Posted March 31, 2016 Share Posted March 31, 2016 Moved to Turbo Powertrains - Pro amore Dei et patriam et populum - Link to comment Share on other sites More sharing options...
