tony_de_whitt Posted March 12, 2016 Share Posted March 12, 2016 Hello Chasing some advice from you good people, Currently attempting a frankenmotor build. Using an ej22 1993 And a bottom end from 1997 outback ej25 Can someone advise on which tensioner I should use on the conversion. My ej22 has the old style 2 bolt tensioner and the ej25 has the single bolt tensioner. At the moment I'm thinking of using the ej22 set up when it all goes back together. Anyone have an opinion on this?? Thx in advance Link to comment Share on other sites More sharing options...
Max Capacity Posted March 16, 2016 Share Posted March 16, 2016 PM m sprank he may know, he's www.infamousperformance.net If your on the east coast, www.AZPinstalls.com may be able to help you with the answer. Just tell them I sent you. 305,600miles 5/2012 ej257 short block, 8/2011 installed VF52 turbo, @20.8psi, 280whp, 300ftlbs. (SOLD). CHECK your oil, these cars use it. Engine Build - Click Here Link to comment Share on other sites More sharing options...
