Abelr Posted March 3, 2016 Share Posted March 3, 2016 Okay. So finally got around to installing up/dp and removing the banjo bolt filter. My question is about the copper washer on the banjo bolt. Would it be okay to reuse or should I just purchase a new one before re installation? Honestly I put the whole thing back together then noticed the little copper washer laying on the floor after the fact. Whoops. Least I fought it before I started her. Thanks in advance for the help Link to comment Share on other sites More sharing options...
08SpecB_DE Posted March 3, 2016 Share Posted March 3, 2016 It's always a good idea to use new copper washers because they are soft but when in a pinch, reusing the old one works 85% of the time. Link to comment Share on other sites More sharing options...
Max Capacity Posted March 3, 2016 Share Posted March 3, 2016 Some have heated the old washer with a small torch, so it grows a bit, then it gives a better crush. But if you had to buy the small propane torch, just buy a new washer from the dealer. 305,600miles 5/2012 ej257 short block, 8/2011 installed VF52 turbo, @20.8psi, 280whp, 300ftlbs. (SOLD). CHECK your oil, these cars use it. Engine Build - Click Here Link to comment Share on other sites More sharing options...
Thinking out side box Posted March 30, 2016 Share Posted March 30, 2016 i get about 5 to 8 reuses out of those. the aluminum ones can be resused 10 to 15 times. Link to comment Share on other sites More sharing options...
