LGTwagon99 Posted February 24, 2016 Share Posted February 24, 2016 I recently picked up a used VF52, and I'm in the process of getting it tuned. However, a vaccum leak is getting in the way of tuning the car. Nothing showed itself on a visual insection, so I hooked up a smoke system to check it out. Once I pressurize the intake system, I can hear air flowing from below the center of the turbo, and I can see a little oil bubbling around the turbo - oil drain pipe gasket. Now my question is, is there any blow by expected on the turbos oil seals when the car is not running? I would imagine once there is pressurized oil in the turbo the leak would be much less if at all, especially under low/no boost conditions. Link to comment Share on other sites More sharing options...
Max Capacity Posted February 25, 2016 Share Posted February 25, 2016 PM JmP6889928 and ask him, he's the expert. 305,600miles 5/2012 ej257 short block, 8/2011 installed VF52 turbo, @20.8psi, 280whp, 300ftlbs. (SOLD). CHECK your oil, these cars use it. Engine Build - Click Here Link to comment Share on other sites More sharing options...
