blawknox977 Posted February 24, 2016 Share Posted February 24, 2016 Hey everyone, On my 05 LGT MT, I have leaking oil from head gasket, 30 PSI in cylinder #2. check engine light for miss fires on 2, 3 ,4. So bad things all around. I just cracked 200k. I will have my mechanic who is a friend pull the motor with me and he can help. But there is so much info out there about performance parts and what fits i just dont know where to start. Can anyone point me in the right direction for heads and if i need a block. Things i would be stupid not to do because the motor is out. parts that need to be upgraded. PLEASE HELP!!! any advice would be much apreciated. This is my DD. Thanks!!!!!! Link to comment Share on other sites More sharing options...
Rhitter Posted February 24, 2016 Share Posted February 24, 2016 Read everything here. Stickies, posts, everything http://legacygt.com/forums/forumdisplay.php/engine-rebuild-threads-engines-only-142.html Read Max Capacity's rebuild thread. My OBXT build Link to comment Share on other sites More sharing options...
Max Capacity Posted February 24, 2016 Share Posted February 24, 2016 Lots of info in the sticky at the top of that link ^ Here, http://legacygt.com/forums/showthread.php/mr-tris-rebuild-threadi-246893.html Let us know if you have any questions. PM "Underdog" for help with parts, he's not to far from you. 305,600miles 5/2012 ej257 short block, 8/2011 installed VF52 turbo, @20.8psi, 280whp, 300ftlbs. (SOLD). CHECK your oil, these cars use it. Engine Build - Click Here Link to comment Share on other sites More sharing options...
boxkita Posted February 24, 2016 Share Posted February 24, 2016 check out the stickies in this section. Build my car Boxkita Track days Link to comment Share on other sites More sharing options...
blawknox977 Posted March 2, 2016 Author Share Posted March 2, 2016 Thankyou very much this is great!! Link to comment Share on other sites More sharing options...
Thinking out side box Posted March 30, 2016 Share Posted March 30, 2016 what ever you do, don't try to adjust the TPS, its not the tps Link to comment Share on other sites More sharing options...
