lovedr79 Posted February 23, 2016 Share Posted February 23, 2016 i have to replace the window master switch in my Legacy. Do i have to take the entire door panel off or will just the trim piece that the switch is screwed to? I have seen some that just pop out but some you have to remove the entire door panel. Link to comment Share on other sites More sharing options...
Max Capacity Posted February 23, 2016 Share Posted February 23, 2016 http://people.csail.mit.edu/ilh/vacation/ the service manual should tell you how. 305,600miles 5/2012 ej257 short block, 8/2011 installed VF52 turbo, @20.8psi, 280whp, 300ftlbs. (SOLD). CHECK your oil, these cars use it. Engine Build - Click Here Link to comment Share on other sites More sharing options...
lovedr79 Posted February 23, 2016 Author Share Posted February 23, 2016 Thank you! Link to comment Share on other sites More sharing options...
