JF1GG29 Posted February 29, 2016 Share Posted February 29, 2016 http://imgur.com/56aC3IE.jpg Terrible picture, but while it seems like one of the pins had rusted, the caliper moved on the bracket freely. Drove for 20 minutes with plenty of hard braking and measured the following temps: F/D: 320F F/P: 320F R/D: 220F R/P: 220F I'm happy to have done the calipers, but it seems that it wasn't the cause of the vibration issue. While I was down there, I checked the front driveshafts for play, and it seemed like both had a little bit. Is that normal or should there be none at all? It seemed that the rears had none. Link to comment Share on other sites More sharing options...
JF1GG29 Posted February 29, 2016 Share Posted February 29, 2016 http://imgur.com/lpWcNlQ.jpg Excuse my winter grime. Painted the remanufactured calipers with duplicolor ceramic caliper paint in gloss black. Massive improvement in appearance over the rusted OE. Link to comment Share on other sites More sharing options...
08SpecB_DE Posted February 29, 2016 Share Posted February 29, 2016 Check your suspension. Your caster looks way off unless it's the angle of the picture. Link to comment Share on other sites More sharing options...
JF1GG29 Posted March 1, 2016 Share Posted March 1, 2016 The steering wheel is turned slightly. Caster is right at about 7° from the last alignment I had two months ago. Link to comment Share on other sites More sharing options...
JF1GG29 Posted March 28, 2016 Share Posted March 28, 2016 I ordered a set of front axles from Raxles and put them on over the weekend. Fairly simple job, though getting all the bolts and arms aligned when putting everything back together was a time-consuming pain in the ass. Creative use of a prybar and a floor jack go a long way! After I replaced the axles, I went on a short highway drive to see if the problem was resolved. It does look like intermittent 60mph - 70mph vibration went away, so I'm relieved about that. The lateral play in the front axles was probably less than 1/16" at the time. However, it seems that the new axles bind under quick cornering at 1/2 to full lock -- I get a very strong shuddering/vibration on the driver's side front whether I'm turning right or left. I'm going to try to get Raxles to send me a new axle, but I have to say, I'm kind of disappointed. I went with Raxles so that I wouldn't have this issue and have to do the replacement twice. Hopefully there won't be any issues with getting the axle replaced. Let's see how this plays out. Link to comment Share on other sites More sharing options...
Bobbo63 Posted March 29, 2016 Author Share Posted March 29, 2016 i think i found it... belts coming outta the passenger rear Link to comment Share on other sites More sharing options...
doobaruGT Posted March 30, 2016 Share Posted March 30, 2016 bad tire? rotate front to rear one at a time. wheel balance? same solution to isolate / identify the wheel. it could be anything, any more info? He wins :-) Updated parts list since original part-out here. Original Full part-out of my LGT HERE! Link to comment Share on other sites More sharing options...
JF1GG29 Posted March 31, 2016 Share Posted March 31, 2016 Often the simplest, cheapest thing. Unfortunately not in my case! I spoke with Marty at Raxles, he's going to replace the joints on my original Subaru axles and send them back to me to see if it helps. Link to comment Share on other sites More sharing options...
Bobbo63 Posted March 31, 2016 Author Share Posted March 31, 2016 thumbs up!!!! Link to comment Share on other sites More sharing options...
