BigBlack-V Posted February 17, 2016 Share Posted February 17, 2016 So the other day I started the car and turned on the lights. They flickered and they all shut off. The only thing that worked was one fog light and the high beams when I put them on. I checked the fuses under the hood and the one(s) behind the coin collector and they are all fine. The only other thing besides a wiring issue I think could be a relay issue. There are 2 (20amp) fuses under the hood so maybe I will buy new ones and see if that fixes the issue. Any thoughts? I was 0. And I'm still a zero. Link to comment Share on other sites More sharing options...
DonnyJagaru Posted February 22, 2016 Share Posted February 22, 2016 Loose battery cable? Bad battery? Link to comment Share on other sites More sharing options...
BigBlack-V Posted February 22, 2016 Author Share Posted February 22, 2016 i was able to fix the lights this weekend but it was odd how it played out. I checked the fuses and relays and all seemed to be working find. I checke the fog bulbs and that was fine. Turns out the fog connector was loose so when I tightened it that bulb worked. The low beams I check the bulbs and the filament looked fine on both. I had a spare H1 laying around and plugged it in and said what the hell why not and sure as shit it worked. I bought two new H1 bulbs and they both work now. Something must have happened to the bulbs that I couldnt see. Good thing it only cost me $26 to fix as I was thinking it was either the DRL module or the stick on the inside of the car. I was 0. And I'm still a zero. Link to comment Share on other sites More sharing options...
