mobstar99 Posted February 17, 2016 Share Posted February 17, 2016 I have a 2011 Legacy 2.5. I'm absolutely in love with the 6th generation 18' grey machined wheels, but they won't fit on 5th generation models. Does anybody know if any after market wheel companies make a similar looking wheel that would fit on 5th generation legacys? 100mm bolt pattern and 55mm offset. any help would be appreciated! Link to comment Share on other sites More sharing options...
FLlegacy Posted February 18, 2016 Share Posted February 18, 2016 Get some 5x100-5x114 adapters problem solved. And you can space it out a little to fill the gap. Link to comment Share on other sites More sharing options...
fredrik94087 Posted February 19, 2016 Share Posted February 19, 2016 http://www.tirerack.com/wheels/WheelCloseUpServlet?target=runWheelSearch&initialPartNumber=T12880485100BMF&wheelMake=Sport+Tuning&wheelModel=T12&wheelFinish=Machined+w%2FBlack+Accent&showRear=no&autoMake=Subaru&autoModel=BRZ&autoYear=2014&autoModClar=Limited get on tirerack and search for BRZ wheels in 18" with 8", 8.5" diameter. They will all fit fine. "It's within spec" - SOA "Depth is only shallowness viewed from the side." - Fredism "So, how much did it cost for your car to be undriveable ." - Stephen (very close friend) "You have done so much it would be stupid to go back." - Sunny of Guru Electronics 2018Q50RS | 2015WrxThread | Shrek Link to comment Share on other sites More sharing options...
mobstar99 Posted February 20, 2016 Author Share Posted February 20, 2016 Thanks for the suggestion, I really appreciate it. Link to comment Share on other sites More sharing options...
mobstar99 Posted February 20, 2016 Author Share Posted February 20, 2016 Can a wheel with a 8 or 8.5 inch diameter fir on a 2011 legacy 2.5? I think that stock wheels I have on there now are 16x7.5 Link to comment Share on other sites More sharing options...
cww516 Posted February 20, 2016 Share Posted February 20, 2016 You can fit an 8.5 wide wheel on there no problem- there's no difference between the 2.5i, 3.6R, or 2.5GT in terms of stock suspension, so anything you see around these parts should fit just fine, unless the owner has done some fender modification or installed coilovers. You'd be hard-pressed to fit an 8.5" diameter wheel, though Link to comment Share on other sites More sharing options...
mobstar99 Posted February 20, 2016 Author Share Posted February 20, 2016 ok perfect, good to know. Link to comment Share on other sites More sharing options...
fredrik94087 Posted February 21, 2016 Share Posted February 21, 2016 He is not telling you an 8.5" wide wheel will not fit. He was correcting your statement of "8.5 inch diameter". The wheel is 18" in diameter.... "It's within spec" - SOA "Depth is only shallowness viewed from the side." - Fredism "So, how much did it cost for your car to be undriveable ." - Stephen (very close friend) "You have done so much it would be stupid to go back." - Sunny of Guru Electronics 2018Q50RS | 2015WrxThread | Shrek Link to comment Share on other sites More sharing options...
dukedevil0 Posted February 24, 2016 Share Posted February 24, 2016 I don't suppose anyone has a picture or good photoshop of the 6th gen wheels above on a 5th gen, preferably a white car? Link to comment Share on other sites More sharing options...
DrD123 Posted March 1, 2016 Share Posted March 1, 2016 well, if you can relax your standards on "good photoshop"... Link to comment Share on other sites More sharing options...
