Scruit Posted February 15, 2016 Share Posted February 15, 2016 Subaru says I need replacement oil return hose under the turbo, and they quoted me almost $1k saying the turbo must be removed to get at it. Sounds like bollocks to me, but? Link to comment Share on other sites More sharing options...
doctorbrody Posted February 15, 2016 Share Posted February 15, 2016 Yeah you can't get to the hose with the turbo installed. It's not that hard to do yourself - you don't even need to get under the car. Just get 2 new turbo exhaust gaskets. Link to comment Share on other sites More sharing options...
Scruit Posted February 15, 2016 Author Share Posted February 15, 2016 k. I'll wait until it warms up a bit. It's not leaking enough to even drip - just a sheen on the side of the trans. Link to comment Share on other sites More sharing options...
Max Capacity Posted February 17, 2016 Share Posted February 17, 2016 I recommend removing the studs and bolting the turbo back on. I guess you that by now. 305,600miles 5/2012 ej257 short block, 8/2011 installed VF52 turbo, @20.8psi, 280whp, 300ftlbs. (SOLD). CHECK your oil, these cars use it. Engine Build - Click Here Link to comment Share on other sites More sharing options...
rmoore5 Posted February 17, 2016 Share Posted February 17, 2016 Subaru says I need replacement oil return hose under the turbo, and they quoted me almost $1k saying the turbo must be removed to get at it. Sounds like bollocks to me, but? Wow $1k, again the dealer creating goodwill to a future customer:spin: I would think the flat rate R&R on the turbo wouldn't be more than 2 hours. The drain hose labor should be included in the R&R. I recommend removing the studs and bolting the turbo back on. I guess you that by now. Maybe the bolt recommendation could be added to your sig. Seriously though I am going to try that on the 05 when I get around to doing the motor. Link to comment Share on other sites More sharing options...
