Dubb Posted February 14, 2016 Share Posted February 14, 2016 Hey guys... so I literally just got done installing my HIDs on my car (I love them btw) but I think I might have done something wrong... After I got done with the installation I took it for a little test drive... I ordered low beam bulbs (H7) but my lights only turn on if I put on my high beams... is that normal ? This is my first time installing HIDs on a car so anything you guys know will help a lot. Thank you Link to comment Share on other sites More sharing options...
waynieRS Posted February 14, 2016 Share Posted February 14, 2016 following Link to comment Share on other sites More sharing options...
RJ255 Posted February 14, 2016 Share Posted February 14, 2016 How are they wired, plugged into the low beam directly? Do you have a relay harness? What kit are you using? Did you try putting the stock bulbs back in to verify the issue is with the HIDs? Link to comment Share on other sites More sharing options...
Dubb Posted February 15, 2016 Author Share Posted February 15, 2016 To be honest on your first 2 questions I'm not too sure... I used a walk through I found on the forums. The kit I used was a Xentec kit, I was recommended it from a friend that has that brand on his car... and no I haven't tried throwing back in the stock bulbs... my other question is, is it bad to have it like that ? I mean if it is then I will remove it right away. Link to comment Share on other sites More sharing options...
RJ255 Posted February 16, 2016 Share Posted February 16, 2016 Well first, make sure you didn't connect the ballasts to the highbeam plugs by accident. May sound silly but it's an easy mistake to make. Second, do your halogen high beams work normally? It's not bad per say to run an HID kit without a relay harness. However it is safer for older cars that have less than sufficient wiring, so that you don't do damage to the factory harness. HID ballasts draw up to twice the power of halogen bulbs on startup, which can be difficult for some cars to handle. A harness will provide more reliable power directly from the battery, and could be the solution to any power issues (inconsistent cold startup or flickering). In short, it (a relay harness that is) is not always necessary, but it's a good idea in the majority of situations. Link to comment Share on other sites More sharing options...
Dubb Posted February 16, 2016 Author Share Posted February 16, 2016 I understand... thank you for helping me out RJ255... I'll go ahead and check my connections and make sure nothing is hooked up wrong... if the problem persists then I'll go ahead and put back the stock bulbs and see if it's really the HID kit. Link to comment Share on other sites More sharing options...
Dsaul23 Posted February 16, 2016 Share Posted February 16, 2016 To get mine to work in my 2006 LGT I had to unplug my DRL harness under the driver side. There was a black and white connector. I unplugged the white one and they work everytime. Link to comment Share on other sites More sharing options...
RJ255 Posted February 16, 2016 Share Posted February 16, 2016 To get mine to work in my 2006 LGT I had to unplug my DRL harness under the driver side. There was a black and white connector. I unplugged the white one and they work everytime. This could potentially affect things. OP if you have factory DRLs try disabling them. Link to comment Share on other sites More sharing options...
Dubb Posted February 17, 2016 Author Share Posted February 17, 2016 I did disable the DRLs... maybe it's just a faulty kit or something Link to comment Share on other sites More sharing options...
Mike07LGT Posted February 18, 2016 Share Posted February 18, 2016 I put the Kensun kit on my car and have had no issues.. it's like $50 on amazon. If you decide to go with something else check it out. Many users have installed this kit without issue and have been happy with the results 03 WRB WRX (RIP) 04 JBP STI (sold) 07 DGM Legacy GT (RIP) 12 OBP STI (DD) Link to comment Share on other sites More sharing options...
Dubb Posted February 18, 2016 Author Share Posted February 18, 2016 Thanks Mike... Ill probably pick that one up... I mean this is what I get for going Ebay lol Link to comment Share on other sites More sharing options...
LGTTusch Posted February 18, 2016 Share Posted February 18, 2016 Same, just installed a Kensun kit in my headlights ($35 over the holidays) and an Apex kit in my fog lights ($30) and no issues with either so far. Though I desperately need to aim both Link to comment Share on other sites More sharing options...
ilover Posted February 19, 2016 Share Posted February 19, 2016 Another thing... Make sure to check and adjust the light beams correctly, to avoid glare with incoming traffic. Link to comment Share on other sites More sharing options...
Mike07LGT Posted February 19, 2016 Share Posted February 19, 2016 Same, just installed a Kensun kit in my headlights ($35 over the holidays) and an Apex kit in my fog lights ($30) and no issues with either so far. Though I desperately need to aim both Does kensun make a kit for the fogs?? Another user here put the apex in his headlights and ended up switching to kensun... it would be cool to have brighter fog lights though to match headlights as well! 03 WRB WRX (RIP) 04 JBP STI (sold) 07 DGM Legacy GT (RIP) 12 OBP STI (DD) Link to comment Share on other sites More sharing options...
LGTTusch Posted February 19, 2016 Share Posted February 19, 2016 Yeah they do, you just go by bulb type. Kensun ran great prices over the holidays but I cheaped out on the fogs. Link to comment Share on other sites More sharing options...
waynieRS Posted February 19, 2016 Share Posted February 19, 2016 what bulbs are in the main and dip beam guys ? Link to comment Share on other sites More sharing options...
LGTTusch Posted February 20, 2016 Share Posted February 20, 2016 H7 for lows and h3 for fogs Link to comment Share on other sites More sharing options...
waynieRS Posted February 20, 2016 Share Posted February 20, 2016 H7 for lows and h3 for fogs but what about high beam bud ? Link to comment Share on other sites More sharing options...
RJ255 Posted February 20, 2016 Share Posted February 20, 2016 but what about high beam bud ? 9005 Link to comment Share on other sites More sharing options...
LGTTusch Posted February 21, 2016 Share Posted February 21, 2016 Don't put hid in highs unless you don't use flash to pass, that's terrible for hids Link to comment Share on other sites More sharing options...
waynieRS Posted February 21, 2016 Share Posted February 21, 2016 Don't put hid in highs unless you don't use flash to pass, that's terrible for hids back roads of australia mate i need all the lights i can Link to comment Share on other sites More sharing options...
LGTTusch Posted February 22, 2016 Share Posted February 22, 2016 Haha fair enough Link to comment Share on other sites More sharing options...
