JBisson Posted February 9, 2016 Share Posted February 9, 2016 So today my legacy randomly started to over heat so I pulled over let it cool off and started driving again and then after a few min it would over heat again and it continued to do this. So I got a oem Subaru t-stat and took it for a drive and it's acting even worse. I did have a lot of coolant dripping from the lower radiator hose area. So I tightened everything up but it's really cold and snowing so I have not continued to mess with it anymore. Sent from my iPhone using Tapatalk Link to comment Share on other sites More sharing options...
gimpydingo Posted February 9, 2016 Share Posted February 9, 2016 I'm going to call out head gasket. Link to comment Share on other sites More sharing options...
johnegg Posted February 9, 2016 Share Posted February 9, 2016 year, model, engine, trans, miles, color? did you install the t-stat gasket ? correctly? Link to comment Share on other sites More sharing options...
JBisson Posted February 9, 2016 Author Share Posted February 9, 2016 It's a 2000 gt manual trans has a slight external head gasket leak. I do believe I installed it correctly but it did seam to be leaking from that area. I will be taking the housing off tomorrow but it got too cold tonight Sent from my iPhone using Tapatalk Link to comment Share on other sites More sharing options...
Osei Posted February 9, 2016 Share Posted February 9, 2016 Do search for burping. May be just an air pocket. o. Link to comment Share on other sites More sharing options...
