OhNineGT Posted January 28, 2016 Share Posted January 28, 2016 Hey guys, Will this fix my problem? I think it is the right sensor... [ame=http://www.amazon.com/Denso-234-4446-Oxygen-Sensor-Ratio/dp/B001F7GK60/ref=sr_1_1?s=automotive&ie=UTF8&qid=1454024088&vehicle=2009-13-64-151--1-6-6-7454-1737-1-1---1-0&sr=1-1&ymm=2009%3Asubaru%3Alegacy&keywords=Air+and+Fuel+Ratio+Sensor%29]Amazon.com: Denso 234-4446 Oxygen Sensor (Air and Fuel Ratio Sensor): Automotive[/ame] Thanks in advance! Link to comment Share on other sites More sharing options...
Shogun506 Posted January 29, 2016 Share Posted January 29, 2016 No don't buy that one! I don't know what code P0134 is, it doesn't show up in the code reference at the top of this forum. I can tell you for sure that if you get P0031 and your upstream oxygen sensor is bad then you have the wrong sensor there. That's a downstream sensor - you need denso upstream number 2349120. Remember! As I said I don't know what that P0134 code is. Figure out what that is before you do anything because if you're getting both codes maybe something different is wrong. When my sensor was broken I only got P0031. Link to comment Share on other sites More sharing options...
OhNineGT Posted January 29, 2016 Author Share Posted January 29, 2016 Thanks! Luckily I did some more research before I bought that one! Got the right one and the CEL is off! Appreciate your help! Link to comment Share on other sites More sharing options...
FJuan Posted January 29, 2016 Share Posted January 29, 2016 The P0134 is related to the A/F sensor, which in most cases is a faulty sensor. Not sure if that's the correct A/F sensor from Amazon, I bought this one from Rockauto and haven't had any problems. DENSO 2349120 OE Style Upstream; DENSO is the OE Manufacturer Air Fuel Ratio Sensor http://www.rockauto.com/info/14/234-9120_SID__ra_t.jpg $94.79 My wife's balls are delicious. Link to comment Share on other sites More sharing options...
Max Capacity Posted January 29, 2016 Share Posted January 29, 2016 Check post #48 http://legacygt.com/forums/showthread.php/idea-web-links-saved-various-parts-219238p2.html 305,600miles 5/2012 ej257 short block, 8/2011 installed VF52 turbo, @20.8psi, 280whp, 300ftlbs. (SOLD). CHECK your oil, these cars use it. Engine Build - Click Here Link to comment Share on other sites More sharing options...
