SubiesRock Posted January 26, 2016 Share Posted January 26, 2016 I have a 2002 Legacy GT LTD that my grown daughter drives, total miles 310K but this engine 160K. I had a new radiator put in this summer. Coolant was disappearing at first and they caught a radiator hose clamp that needed tightened. Everything good until now (January). It smoked the other day and I found coolant pooled mostly on drivers side top of engine under the intake. I checked oil and it looks fine on the dipstick, not cloudy or bubbly or anything. The car has not been overheating. I also had put the conditioner in this summer after getting the radiator. The car has a ton of miles on it but as most Subies do it still does great except for this. I read typically the head gasket on the drivers side will leak externally at the bottom rear. Trying to check it myself but not finding anything obvious. I know there are one or two small hoses under the intake but I can't tell which they are. My husband passed away this last year and although we have always driven Subaru's (7 of them) this is a new one on me and I just don't have the knowledge he did. Any advice would be appreciated before I have to take it to the mechanic. Link to comment Share on other sites More sharing options...
Osei Posted January 26, 2016 Share Posted January 26, 2016 Probably the T in the water bypass pipe where it t's to go to the throttle body. Could even be the hose itself. O. Link to comment Share on other sites More sharing options...
Moosegoose6036 Posted January 27, 2016 Share Posted January 27, 2016 There's a bleeder screw right underneath the throttle body, make sure that's closed. I've accidentally forgot to close when replacing a radiator and yeah, it'll pour onto the top of the block. good luck Link to comment Share on other sites More sharing options...
SubiesRock Posted February 1, 2016 Author Share Posted February 1, 2016 I finally got it back from a well meaning retired mechanic who was more worried about the brake pads than finding the source of the coolant leak! That night I could see a short hosem, probably the hose you referred to Osei. Guess I got the light just right in the dark and there it was glaring at me! Took it to a real mechanic and he said looked like a critter had been gnawing on it. Got it replaced and we're good as new! Well, as good a new as a 300K car can be. She still runs down the road great! Thanks for the answers, it relieved my mind. Just knew I didn't have a head gasket problem with it. Link to comment Share on other sites More sharing options...
