TTercel Posted January 24, 2016 Share Posted January 24, 2016 Hey all, I had a problem occur recently with my 2005 Legacy GT. What happened was, I entered on to a highway and I was doing about 4000rpm in third gear creeping into boost and the car shuttered and lost power. I had a CEL on already for my STi uppipe so not sure if another appeared, but when I got home a reset the computer and the CEL blinked at me for 10 seconds while a revved the car in neutral. Also for some odd reason the car is now showing the car has an empty tank of gas when I have a quarter tank left. The car is running rough and it sounds like it's running on three cylinders. No smoke and fluids are normal. The car has a catback and a STi uppipe. It is also protuned. Any suggestions? I will be reading the codes later tonight. Link to comment Share on other sites More sharing options...
TTercel Posted January 25, 2016 Author Share Posted January 25, 2016 Update: CEL was for a cylinder 3 misfire and I got the fuel gauge to work after another hard reset (disconnecting the battery). Time to dig into the ignition and fuel system. Yay! (insert sarcasm) BTW I know there are a lot of misfire threads and I've read a lot of them I just haven't read a scenario where it involved the fuel gauge as well. Link to comment Share on other sites More sharing options...
TTercel Posted January 27, 2016 Author Share Posted January 27, 2016 Solved! Spark plugs were in horrible shape and cylinder 3 ignition coil was dead. Link to comment Share on other sites More sharing options...
Max Capacity Posted February 1, 2016 Share Posted February 1, 2016 Glad to found and fixed the problem. Good Work. 305,600miles 5/2012 ej257 short block, 8/2011 installed VF52 turbo, @20.8psi, 280whp, 300ftlbs. (SOLD). CHECK your oil, these cars use it. Engine Build - Click Here Link to comment Share on other sites More sharing options...
