drakepeterdrake Posted January 14, 2016 Share Posted January 14, 2016 I asked my mechanic to get me brighter headlights after one of my lights burned out on my 2005 GT wagon. He found and installed 100w Hella bulbs, which are listed "for off-road use only." He suggested I come back in a month so that we could check the sockets to make sure they were handling the higher wattage OK. Is there anything else to look out for? Thanks. P Link to comment Share on other sites More sharing options...
I3eXa Posted January 14, 2016 Share Posted January 14, 2016 bad idea. Those will melt housings or wiring Link to comment Share on other sites More sharing options...
bluesuby Posted January 14, 2016 Share Posted January 14, 2016 As stated in many previous posts, Candlepower sells Osram 65 watt H7 bulbs which are safe for the harness. They too are marked "off road" use only. I'd hesitate to use 100 watt bulbs except on European cars/trucks which have a heavier duty harness. By the time your mechanic does his check it may be too late. Installation of the headlight bulbs is easy, and Candlepower will ship 2 bulbs for $36 with free shipping. Yo'll have them on Monday. Just make sure you wear latex gloves and/or do not touch the glass surface of the bulbs. Link to comment Share on other sites More sharing options...
drakepeterdrake Posted January 14, 2016 Author Share Posted January 14, 2016 Thanks, I ordered the OSRAM's. P Link to comment Share on other sites More sharing options...
RJ255 Posted January 14, 2016 Share Posted January 14, 2016 100w can also burn the projector bowl and eventually diminish the output severely. Osram Rallye H7 (65w) are a good choice. Link to comment Share on other sites More sharing options...
bluesuby Posted January 16, 2016 Share Posted January 16, 2016 100w can also burn the projector bowl and eventually diminish the output severely. Osram Rallye H7 (65w) are a good choice. Nobody needs that. Link to comment Share on other sites More sharing options...
