Ryany461 Posted January 11, 2016 Share Posted January 11, 2016 Hi all: I recently did a coolant flush on my 2011 subaru legacyou 3.6R. I used prestone coolant 50/50 mix. I wanted to know if this is OK or should I swap it again and use subaru super coolant. I know subaru recommends that but then again every manufacturer recommends their own brand. Any advice would be great. Thanks. Link to comment Share on other sites More sharing options...
fedaykin Posted January 12, 2016 Share Posted January 12, 2016 Should be fine, as long as you bled the system properly. Link to comment Share on other sites More sharing options...
Ryany461 Posted January 12, 2016 Author Share Posted January 12, 2016 Hi thanks for the response and yes I did a complete flush. Drained all the original coolant ran water through it until it came out clear, filled it with water and a cleaner ran for ten minutes. Drained that out and refilled with new coolant. Link to comment Share on other sites More sharing options...
YeuEmMaiMai Posted January 16, 2016 Share Posted January 16, 2016 use whatever color coolant the Subaru coolant was. Make SURE you mixed it for the weather in your area Link to comment Share on other sites More sharing options...
NORULZleggy Posted January 25, 2016 Share Posted January 25, 2016 You can use what ever you want to use. I use Amsoil coolant. You by no means have to run Subaru OEM stuff ever. Also your warranty will be fine. I have been doing it for years Link to comment Share on other sites More sharing options...
ilover Posted February 12, 2016 Share Posted February 12, 2016 Did you use distilled water in the process of dilution of the coolant system? Link to comment Share on other sites More sharing options...
Thinking out side box Posted March 30, 2016 Share Posted March 30, 2016 distilled water is not required with the Prestone, therefore would be a complete waste. Link to comment Share on other sites More sharing options...
