Kcco138 Posted December 31, 2015 Share Posted December 31, 2015 I am looking at picking up a set of winters and from what I can tell they won't fit, but maybe I interpreted the info wrong....what so you guys think? Thanks in advance! https://bend.craigslist.org/wto/5348731753.html Link to comment Share on other sites More sharing options...
JmP6889928 Posted December 31, 2015 Share Posted December 31, 2015 They will fit. Exactly the same as your stock LGT wheels. 17x7 +55 5x100 is exactly the same. Link to comment Share on other sites More sharing options...
Kcco138 Posted December 31, 2015 Author Share Posted December 31, 2015 I was concerned with the beefier tire size since stock (which I'm running) is 215/45/17 I think... Thank you very much! Btw the Turbo is performing beautifully! Link to comment Share on other sites More sharing options...
JmP6889928 Posted December 31, 2015 Share Posted December 31, 2015 Right on. Glad it's running well. Link to comment Share on other sites More sharing options...
ashwinearl Posted December 31, 2015 Share Posted December 31, 2015 Isn't 235 width pushing it on 7" width rims according to the FAQ? Isn't 'narrower' as in OEM size preferred for winter tires in snow to cut through snow to pavement. For just cold dry/wet pavement I know that I don't like my 205 width winter tires and I am sizing back up to OE 215. But I had been concerned with going to 225 so was surprised to see 235 winters. Link to comment Share on other sites More sharing options...
JmP6889928 Posted December 31, 2015 Share Posted December 31, 2015 Narrower is better for snow and inclement weather but remember that a 235 is only 20mm total wider which is only about 7/8"-not that much. The wheels fitment is correct. Link to comment Share on other sites More sharing options...
DrD123 Posted January 1, 2016 Share Posted January 1, 2016 those tires are a lot taller than your current setup (235/55-17 vs your 215/45-17) - about 2.6" taller! your speedometer is going to off (slow) by 10% or so. The rims will fit, but if you are lowered, you might rub. 235's seem a little wide for a 7" tire, but maybe you can get away with it for winters? Link to comment Share on other sites More sharing options...
Kcco138 Posted January 2, 2016 Author Share Posted January 2, 2016 I was interested if I could've got them at a better price, and the more reviews I read found out they arent that good in snow so....I decided against them. Thank you guys for the input! Link to comment Share on other sites More sharing options...
