ashwinearl Posted December 19, 2015 Share Posted December 19, 2015 I had my timing belt/water pump/thermostat changed by a mechanic recently. I don't see any coolant leaking anywhere. The coolant level in the expansion tank was low when I get home. I filled it to the full level and drove to work the next day. Again when I got home the level in the expansion tank was low. I provided a gates kit, OEM water pump, OEM thermostat, OEM green coolant, and OEM coolant conditioner. Does this point to a air in the system and probably not going through the full Subaru way of burping the system. I am going to get one of those spill free coolant funnels and go through the burping procedure. Link to comment Share on other sites More sharing options...
bluesuby Posted December 19, 2015 Share Posted December 19, 2015 I'm thinking it'll burp itself. Just takes time. Link to comment Share on other sites More sharing options...
r.lee89 Posted December 19, 2015 Share Posted December 19, 2015 It takes a couple drive cycles to get a proper reading on the overflow tank when it cools down the rad will try to suck in some coolant from the overflow. It usually takes 5-6 heating to cooling cycle to get a good reading on the tank if its still low then it may have a leak or burning coolant. Link to comment Share on other sites More sharing options...
ashwinearl Posted December 21, 2015 Author Share Posted December 21, 2015 It seems stable now. I did jack the left front up and ran it with the cap off and some air did come out. I squeezed the radiator hose a little. I didn't have spill proof funnel in there so didn't want to make too much of a mess. And I topped it off at the cap. Link to comment Share on other sites More sharing options...
Dispatch20 Posted December 22, 2015 Share Posted December 22, 2015 Totally normal. No need to try and burp it. It will settle itself after a few days. Link to comment Share on other sites More sharing options...
