RustyRuu Posted December 18, 2015 Share Posted December 18, 2015 hey guys, i finally got my block to a machine shop and it was surprisingly ok. even with cylinder wall scuffing/scratching/scoring. they hooned it out and said it was still within spec and still round to reuse the pistons. rods were strait and also within spec to use a standard size bearing. no oversized parts are going to be needed is what i was told. so my question is what bearing to get. i probably know the answer. and that is that oem is the best. ACL bearings like to spin. and anything else is garbage if i plan to keep the car for a while. i just need to hear this from someone else though since i cant make decisions for myself. Link to comment Share on other sites More sharing options...
Max Capacity Posted December 20, 2015 Share Posted December 20, 2015 Been a couple of day's. I'd PM Underdog or ask Mike or Rey at http://www.AZPinstalls.com Hint you can buy from them and get the right parts the first time and the best customer service. 305,600miles 5/2012 ej257 short block, 8/2011 installed VF52 turbo, @20.8psi, 280whp, 300ftlbs. (SOLD). CHECK your oil, these cars use it. Engine Build - Click Here Link to comment Share on other sites More sharing options...
